Homework Helper
- 7,833
- 532
The Galileo experiment, and astronaut Scott's demonstration of it, was not accurate enough to show variations in gravity due to mass distribution. A 15 kg dumbell and a .15 kg baseball held above the moon surface will accelerate toward the moon surface at the same rate unless you can measure the difference to about 1 part in 10^25. But if you could measure the acceleration to that level of accuracy, you would find that the dumbell's acceleration will vary slightly depending on its orientation, whereas the baseball's acceleration would not.Cres Huang said:Can you explain:
- How abut the surface and shape?
- Didn't David Scott's hammer fell in sync with feather, the mass, size, shape, and surface are clearly very different?
- The different size, and weight, of the balls fall in uniform acceleration in all experiments I have learned, when the friction of the air is neglected?
- Galileo's inclined plane experiments show the uniform acceleration of different sizes of spheres, by times-squared law regardless of the sizes? I believe he had done very intensive studies on this, if not the most. Great man like him would not give up finding the truth in my view.
- I believe there are countless experiments out there. However, I have been searching for years. Would you kindly direct few falling body experiments that show otherwise? Video clips would be perfected, but anything will do. Thank you. Help, anyone?
AM
