Why is Point A in Compression in a Simplified Crankshaft with a Load P?
The discussion revolves around understanding why point A in a simplified crankshaft is considered to be in compression when subjected to a load P. Participants explore the mechanics of bending moments and stress distribution in beams, particularly focusing on the implications of point A's position relative to the beam's curvature.
  • One participant expresses confusion about the classification of stress at point A, noting that both their calculations and the solutions indicate positive stress values, which they associate with tension.
  • Another participant explains that in bending, the concave portion of a beam is in compression while the convex portion is in tension, suggesting that point A is in the concave portion.
  • A different participant proposes visualizing the forces acting on point A by eliminating a section of the crankshaft to clarify the bending effects.
  • One participant questions how to determine if point A is in compression when it is located on the side of the beam, indicating a lack of clarity regarding the influence of load P on stress classification.
  • Another participant confirms that in a modified scenario where the load P acts downwards, point A would be in tension, emphasizing the importance of concave versus convex positioning rather than absolute top or bottom placement.
  • One participant acknowledges a previous misunderstanding and seeks clarification on the stress state of point A in different configurations of the beam.
  • A later reply points out that point A in the first diagram is not positioned the same as in the second diagram, suggesting that the context of the diagrams is crucial for understanding the stress state.
Participants exhibit a mix of understanding and confusion regarding the stress state at point A, with some agreeing on the principles of bending while others remain uncertain about the implications of different load orientations and beam configurations. The discussion does not reach a consensus on the classification of stress at point A in all scenarios presented.
Participants express uncertainty about the definitions of tension and compression in relation to the position of point A and the effects of load P. There are unresolved questions regarding the application of bending theory to different configurations of the crankshaft.
yonese
Summary:: I'm stuck on a year 2 mechanics question. I have this simplified crankshaft with a load P at the end. The solutions to the exercise have said that point A is in compression due to a bending moment but I don't understand why that is. The solutions and my calculations have both come out with positive values for the stress at A, and I thought a positive value for stress = tension, negative = compression.
The moments (and forces) have directions that can be determined by the sign.
But for a beam in bending, you have the following situation:
When under the bending moment ##M##, the point on the convex portion (bottom) of the beam is in tension, but the concave portion (top) of the beam is in compression. The point A of your crankshaft would be in the concave portion.
Welcome, yonese! :cool:
If we eliminate section b2 of the crankshaft, could you see the direction of the forces acting on point A due to bending more clearly?
Signs are only an arbitrary convention.
Thank you! I hadn't thought of eliminating section b2, which does make it simplier to understand the forces acting on the beam. I can understand whether point A would be in compresssion or tension if it were right on top of beam or under the beam, but since point A is 'on the side' of the beam, how would you determine if its in compression or not?
I haven't included load P when imagining the forces acting on point A. I've just visualised b1 as a simple beam.
Thanks. I completely forgot I had learned this... Thanks for refreshening my memory.
Someone has kindly pointed out that I have attached two images... Could you tell I'm new? Correct me if I am wrong, but if I were the find the stress at point A in the second image (greyed out one), point A would be in the concave portion and so be in tension, as the load P is now driving downwards instead of sideways?
Yes, in the greyed out image, point A would be in tension.
It is not a question of 'top' or 'bottom', it's a question of 'concave' and 'convex'. So it works in any position. Just imagine your part made out of rubber and imagine how it would deform under your load. If you're pulling on the handle (in any direction), the concave shape of the beam will be on the side that you are pulling, thus in compression.
For figure Q5, point A would be under compression load, which would be the opposite to the situation shown in the greyed diagram.
Point A in your first diagram Figure 1 is not in the same place as point A in your second diagram Figure Q5.
  • · Replies 32 ·
