Why is Si indirect semiconductor
  • Context: Undergrad
  • Thread starter Thread starter vani_lj
    Semiconductor Si
Silicon (Si) is classified as an indirect bandgap semiconductor due to the non-alignment of the maximum of the valence band and the minimum of the conduction band at the same k-vector. This misalignment necessitates the involvement of phonons for electron-hole recombination, as optical photons alone lack sufficient momentum. In contrast, materials like Gallium Arsenide (GaAs) exhibit direct bandgaps where recombination can occur without additional excitations. The indirect nature of Si's bandgap is influenced by its covalent bonding structure and the properties of its s and p orbitals, which dictate the energy levels of the bands.
  • Understanding of semiconductor physics
  • Familiarity with band structure diagrams
  • Knowledge of k-space and k-vector concepts
  • Basic principles of electron-hole recombination
  • Study the band structure of Gallium Arsenide (GaAs) to compare direct and indirect bandgap semiconductors.
  • Explore the tight binding approximation and its application in semiconductor band structure analysis.
  • Investigate the kp-perturbation theory and its role in understanding bandgap characteristics.
  • Research the effects of lattice strain on semiconductor properties, particularly in "stretched silicon" technologies.
Students and professionals in materials science, semiconductor physics, and electrical engineering, particularly those focused on semiconductor device design and optimization.
vani_lj
Can anybody explain...
what makes silicon indirect band semiconductor?
thanks in advance
Vani
Look at the band structure diagram.
http://en.wikipedia.org/wiki/File:Si-band-schematics.PNG
Find the maximum of the valence band and the minimum of the conduction band.
They are not at the same k-vector.
Holes and conduction electrons will be found near the maximum/minimum. In order for a hole/electron pair to recombine they must "get rid" of the difference in k. An optical photon carries next to no momentum, so some other elementary excitation like a phonon has to be created.
In GaAs on the other hand, min and max occur at the same k. Holes and electrons can recombine and emit just a photon.
The same hold vice-versa for absorption of a photon.
@M Quack, thanks for the explanation...
But I am still searching for answer that what makes energy band minima to occur at k other than zero in Si.
Hmm, that is just the way the band structure works out with the number of electrons on Si, covalent bonds, and so on. I don't think that you can find an argument based on symmetry.
BTW, Ge and diamond also have indirect band gaps.
The "stretched silicon" invented in the 90's reduced the degree of indirectness of the gap and allowed for more efficient silicon switching speeds. The idea was to grow silicon layers on mismatched substrates that were hot. When the wafer cooled, the silicon was stretched into a slightly different lattice constant.
I suppose there should be some qualitative argument using e.g. tight binding approximation on how the valence band and conduction band change at k=0 with k using kp-perturbation theory. As both bent downward, the band gap must be indirect.
The valence and conduction band are qualitatively due to the s and p orbitals of Si. The s orbitals are lower in energy than p. On the Gamma point, the total bonding-antibonding splitting is larger for s than for p orbitals. Taken together, the lowest valence band has s-character and is well separated from the highest valence band which has pure p character. The mainly anti-bonding p and s type conduction bands are nearly degenerate in energy. Once the Gamma point is left, the kp term will mix s and p bands. The p type valence band and s-type conduction band will repell whence the valence band has a maximum at k=0. On the other hand the s and p type conduction bands will repell even stronger as they are nearly degenerate. Hence the lowest conduction band will also have a maximum at k=0. If we believe in k=0 being the absolute maximum of the valence band then Si has to have an indirect band gap.
@DrDu, Thanks for the explanation...
