Why is sinh-1(x) not equal to 1/sinh(x)?
The discussion revolves around the notation and meaning of the function sinh-1(x), specifically questioning why it is not equivalent to 1/sinh(x). Participants explore the conventions in mathematical notation regarding inverse functions and their representations.
  • Some participants assert that sinh-1(x) is defined as arcsinh(x), the inverse hyperbolic sine function, rather than 1/sinh(x).
  • Others argue that the notation sinh-1(x) is merely a convention for indicating the inverse function, similar to how sin-1(x) represents arcsin(x).
  • There is a discussion about the notation for reciprocal functions, with some suggesting that 1/sin(x) is represented as csc(x) and questioning how to denote 1/sin^2(x).
  • Some participants express confusion over the use of the -1 superscript, suggesting it can lead to ambiguity between inverse and reciprocal interpretations.
  • A later reply mentions that the natural operation between functions is composition, which may clarify why f^{-1} denotes the inverse function rather than a reciprocal.
  • One participant shares a personal preference for using arcsinh(x) over sinh-1(x) to avoid ambiguity.
Participants generally agree that sinh-1(x) represents the inverse hyperbolic sine function, but there is disagreement regarding the implications of the notation and its potential for confusion. The discussion remains unresolved regarding the best practices for denoting these functions.
Some participants note that the notation can conflict with multiplicative interpretations, and there is a lack of consensus on how to best represent certain functions, particularly in relation to powers and inverses.
This discussion may be useful for students and educators in mathematics who are exploring function notation, particularly in the context of inverse functions and their representations.
Stephanus
Dear PF Forum.
I saw once that sinh-1(x) is arcsinh(x). The reverse of sinh
Why not sinh-1(x) is 1/sinh(x)?
While x-1 = 1/x
Is it just a 'convention' between mathematician?
Thanks.
Mathematics news on Phys.org
Stephanus said:
Dear PF Forum.
While x-1 = 1/x
Thanks.
For the same reason that [itex]\sin^{-1}(x)=\arcsin(x)[/itex]. It's merely a convention. Meanwhile, [itex]1/\sin(x)[/itex] is instead given the function name [itex]\csc(x)[/itex] and similarly, [itex]1/\sinh(x)=csch(x)[/itex].
Wow, that fast. Thanks!
So what is 1/sin(x)? No power?
And what is sin-2(x)? 1/sin2(x)?
Csc, cosecant? If it's cosecant than it's ##Arcsin(\sqrt{1-sin^2(x)})##
Right, you wouldn't represent 1/sin(x) with a power. You'd leave it as such or replace it with csc(x).
1/sin2(x) doesn't appear often enough to warrant much criticism about how it should be denoted. I would always leave it in that form, but if you're unhappy with it or have other reasons to change it, the most obvious choice is to go with csc2(x), but never make it sin-2(x) because that just causes confusion.
How so?
[tex]\csc(x)=\frac{1}{\sin(x)}[/tex]
while
[tex]\arcsin(\sqrt{1-\sin^2(x)})=\arcsin(\sqrt{\cos^2(x)})=\arcsin(|cos(x)|)[/tex]
Mentallic said:
Right, you wouldn't represent 1/sin(x) with a power. You'd leave it as such or replace it with csc(x).1/sin2(x) doesn't appear often enough to warrant much criticism about how it should be denoted. I would always leave it in that form, but if you're unhappy with it or have other reasons to change it, the most obvious choice is to go with csc2(x), but never make it sin-2(x) because that just causes confusion.How so?
while
The answer 'convention' in previous post is enough. It's just that in SR forum, someone says ##T = \frac{c}{a} sinh^{-1}(\frac{at}{c})## I calculate it using ##T = \frac{c}{a * sinh(\frac{at}{c})}##. I'm having trouble accepting sinh-1 is not 1/sinh. Once you said, it's a 'convention', I let that go.
Thanks.
You're welcome. Whenever you see a trig function with a -1 power, always think of the inverse and not the reciprocal.
This convention is not an oddity though, it is related to the fact that the natural, generally defined operation between functions is composition rather than multplication. ##f^{-1}## is the inverse of ##f## under the composition operation, not under multiplication, and in the same way ##f^n## designates ##f## iterated ##n## times. Of course it can conflict with usage of multiplicative exponent sometimes, but generally the composition interpretation is the default one (polynomial functions are the main exception I guess).
wabbit said:
This convention is not an oddity though, it is related to the fact that the natural, generally defined operation between functions is composition rather than multplication. ##f^{-1}## is the inverse of ##f## under the composition operation, not under multiplication, and in the same way ##f^n## designates ##f## interated ##n## times.
Okay, it's a matter of "favor"? In variable it's the power of division, right?
Btw can I ask here?
Proper acceleration in Relativity.
We can go further and define the proper acceleration of the particle by
##A^{\mu} = \frac{dU^{\mu}}{d\tau}##
What does this symbol ##\mu## mean?
Of multiplication rather. ##x^{-1}## is the multiplicative inverse of ##x##, defined by the equation ##x^{-1}×x=1##, while ##f^{-1}## is the composition inverse of ##f##, defined by the equation ##f^{-1}\circ f=Id## (##1## and ##Id## being the identity element of the corresponding operation).
But yes, it is a matter of context / usage, the exponent notation generally refers to some operation iterated or inverted, but which operation is implied can be ambiguous.
Btw can I ask here?
Ah, completely unrelated usage : ) It's just an index here (corresponding to the components of the vector), not an operation.
Yes. I understand completely
wabbit said:
##f^{-1}\circ f=Id## (##1## and ##Id##.
Yes.
Ah, I see. Thanks.
My math professor rants about this endlessly =D
Basically, the -1 superscript is just an unfortunate convention of writing for "inverse" that we somehow got stuck with. So sinh-1(x) should be read "inverse hyperbolic sine of x" (sometimes sinh(x) will be pronounced like "Cinch of x") rather than "1 divided by the hyperbolic sine of x". Personally though I very much prefer to write arcsin(x) because 1.) words like "Arcsine" and "Arctangent" just sound so pretty and 2.) they avoid any possible ambiguity.
Yeah I (being a perfectionist) have trouble with this term either. But who I am to protest.
...they avoid any possible ambiguity
That's why I choose computer programming. No ambiguity in programming language :biggrin:
micromass said:
So, what is
1. "2" + "2" -> ??
2. "2" + "3" -> ??
3. What's the difference between NaN and NaP?
4. Why [1,2,3] + 2 is False? I see no comparison in [1,2,3] + 2
5. Why [1.2.3] + 4 is True? Are No 4 and No 5 binary operators?
6. Is [1,2,3] = 1 and 2 and 3?
7. Why 2 / (2 - (3/2 + 1/2)) = NaN.00000013. NaN with point? I see that 2/(2-(3/2+1/2) = 2/0 = NaN
8. Why + 2 = 12?
9. Why 2 + 2 = Done?
10. Shouldn't Range (1,5) -> (1,2,3,4,5) not (1,4,3,4,5)?
Care to tell me how it works? :smile:
xkcd - complicated math humor.
I think I didn't get the joke :smile:
That's alright- it was a bad joke!
By the way, you titled this thread "negative power of a function". When a "-1" is used to indicate the "inverse function", as in "[itex]f^{-1}[/itex], that is not considered a "power".
Yeah. Like saying "Achilles can't catch the turtle no matter how fast he runs"
Now you tell me after all the calculation that I make using 1/sinh(x) instead of arcinh(X) :smile:
  • · Replies 24 ·
  • · Replies 28 ·
  • · Replies 36 ·
  • · Replies 75 ·
  • · Replies 85 ·
10K
