Why is the work of a constant force conservative?
The discussion clarifies that the work done by a constant force is conservative when it is independent of the path taken between two points, A and B. It emphasizes that while sliding friction and drag forces are constant in magnitude, they are not conservative due to their dependence on the direction of velocity. The work done by a conservative force is zero along a closed path, and the line integral of a constant force can be computed without considering the specific path, relying solely on the endpoints. This conclusion is supported by mathematical principles that define conservative forces.
  • Understanding of conservative forces and their properties
  • Familiarity with vector mathematics and line integrals
  • Knowledge of frictional forces and their characteristics
  • Basic principles of mechanics, including work and energy
  • Study the mathematical definition of conservative forces in physics
  • Learn about line integrals and their applications in calculating work
  • Explore the differences between conservative and non-conservative forces
  • Investigate real-world examples of conservative forces, such as gravitational and elastic forces
Students of physics, educators teaching mechanics, and anyone interested in understanding the principles of work and energy in conservative systems.
AntoineCompagnie
Why for a given constant force, in a study reference system, which point of application moves from A to B, the work of the force is conservative?
The only thing I know is that if the angle ##(\vec{F},\vec{AB})## is acute ##W_{AB}## is an engine work else, its resilient.
Some constant forces are not conservative, sliding friction, for example.
Sliding friction is not a constant force. Its magnitude is constant but the direction is opposite to the velocity.
If the direction of the velocity is constant, then both the magnitude and direction of the sliding friction force vector are constant.
If the magnitude and direction of a vector are constant, then the vector is constant. Yet, friction is not conservative.
Another example is the drag force on a falling object that has reached terminal velocity in air. The drag force is constant, but it is not conservative.
http://www.britannica.com/science/conservative-force
A function f(x) is not constant function, even in case x has a definite value. Friction depends on the direction of velocity. The work done between points A and B and back to B to A is not zero, because the velocity changes sign in the reverse path.
The force is conservative, when the the work of the force does not depend on the path between points A and B. Along a closed path, the work is zero. In case of constant force, if the work is positive while the point of application moves from A to B, it is negative when moving back to B to A. Look at the angles between force and displacements (the blue and green vectors in the figure).
The workdone by a conservative force is independent of path. We find the work done by doing a line integral for all kind of force. So to check just take any constant force like ai + b j and integrate that with dl along any curve you want. You will see that you don't have to put the information of curve while solving the integration. Just the end points will solve it.
So mathematics tells that constant force doesn't depend on path.
And constant force means it doesn't depend on X,Y,Z
  • · Replies 31 ·
