Why is there a sharp spike of blue light in my spectrometer readings?
  • Context: Undergrad
  • Thread starter Thread starter Newtons Apple
    Led Spectrometer
The discussion centers around the unexpected spectral readings from a spectrometer, particularly the presence of a sharp spike of blue light in measurements of various light sources, including LEDs and incandescent bulbs. Participants explore the characteristics of light emissions, the role of phosphors in LEDs, and the interpretation of spectral data.
  • One participant notes a consistent sharp spike of blue light in all their spectrometer readings, questioning why this blue light is separate from the main bell curve of other colors.
  • Another participant expresses skepticism about the smoothness and similarity of the spectral curves, suggesting they may not accurately represent the light sources.
  • Some participants propose that "white" LEDs typically include a UV-excitation source and phosphor material that re-emits light, which could explain the observed UV peak.
  • There is a historical reference to the development of white LEDs, suggesting that different approaches were taken in different regions, with Japan utilizing UV sources and phosphors effectively.
  • A participant inquires whether the observed properties of LEDs, particularly the UV peak, are characteristic of all LED lights and questions the necessity of this feature.
  • Another participant asks if incandescent bulbs or red LEDs have been measured, indicating a desire for comparative data.
  • One participant mentions the availability of information online about LED lighting spectra, cautioning that some may be inaccurate.
  • A later reply suggests checking the spectrum of the Sun to rule out potential issues with the spectrometer's calibration.
  • Another participant emphasizes the need for proper calibration of the spectrometer using a blackbody source for accurate readings.
Participants express various viewpoints regarding the spectral characteristics of LEDs and other light sources, with no consensus reached on the reasons for the observed blue light spike or the accuracy of the spectral data. Multiple competing explanations and uncertainties remain in the discussion.
Participants note potential limitations in the measurements, including the need for proper calibration of the spectrometer and the influence of different light sources on spectral readings. There is also mention of the variability in LED designs and their spectral outputs.
Newtons Apple
Hi! Man, I haven't posted here in a while... So I bought a cheap spectrometer and have been measuring light output of many many things. One thing is common from ALL of my readings.. Each LED or light bulb I measure has a sharp, tall narrow band of blue being put out and then a drop off of cyan/lime green and then a bell curve of the other colors. See these two images. One is from my range hood in my kitchen, the other is a 60 watt bulb in my living room.
Why is blue so removed from the rest of the bell curve? Why isn't it part of the main bell curve?
Now look below at some of my plant grow lamps. One of the lamps is UV-A freqency. When I look at the light when it's on, it's to my eyes a very light purple. When I look at the graph below though, it starts roughly at 390nm but the graph shows it as a dark blue. Shouldn't it show violet in at least some amount?
Science news on Phys.org
I know very little about this subject but I am very suspicious of the shape of those curves. They look both smooth (which I would not expect from any light source) and similar (whoch makes me wonder if they're copies).
Most "white" LEDs are including an UV-excitation source surrounded by phosphor material reemitting light in the visible range. That UV peak is coming through and you can observe it by spectrometer.
I believe that while the West was looking at band gap devices to make a white LED, Japan did it using a UV source and phosphors, and won the race. Lateral thinking and practicality.
Interesting.. is this a property of LED lights in general? Will all LED's have a significantly higher UV peak towards the blue then? WHy is this needed?
Have you measured any incandescent light bulbs? How about a red LED?
There is plenty of info to be found on the web about the spectrum coming from LED lighting. Some may be false. Do a search.
View attachment 354433View attachment 354435
The "60 Watt bulb" you mention apparently is a standard LED replacement bulb with an output giving approximately the illumination level as a 60 Watt incandescent bulb. To the human visual system it appears to produce White light.
Judging from the spectrum you show, the actual LED in this bulb produces a narrow band of blue light. The broad-band portion of the spectrum is due to the presence phosphors (as mentioned by @Gleb1964 above) which fluoresces.
Now look below at some of my plant grow lamps. One of the lamps is UV-A frequency. When I look at the light when it's on, it's to my eyes a very light purple. When I look at the graph below though, it starts roughly at 390nm but the graph shows it as a dark blue. Shouldn't it show violet in at least some amount?
There is a very informative Wikipedia page covering LEDs.
Link for Main LED entry: https://en.wikipedia.org/wiki/Light-emitting_diode#
Link for White LED section: https://en.wikipedia.org/wiki/Light-emitting_diode#White_LEDs
Link for Phosphor-based White LED section:
https://en.wikipedia.org/wiki/Light-emitting_diode#Phosphor-based_LEDs
Added in Edit:
The following figure is from the above Wikipedia page
The following information for figure comes from Wikimedia Commons.
Original uploader description: Spectrum of a "white" LED showing blue light directly emitted by the GaN LED and the stokes shifted yellowish light emitted by the Ce:YAG phosphor. Spectrum taken by me (Deglr6328) using an Ocean Optics HR2000 spectrometer [http://www.oceanoptics.com/] with a high-OH solarization-resistant fiber optic light guide. This spectrum is not calibrated for intensity.
Author: The original uploader was Deglr6328 at English Wikipedia.
  • Love
Then, a spectrometer with absolute radiometric calibration using a blackbody source at a specific temperature is required.
  • · Replies 34 ·
11K
