Why is V=fl a dispersion relationship ?
The discussion clarifies that V=fλ is often referred to as a dispersion relationship, particularly in the context of non-dispersive waves where wave velocity is determined by the medium. It establishes that in sound waves, the wave velocity (V) is fixed by the properties of the medium, while frequency (f) and wavelength (λ) are interdependent. The conversation also highlights that all waves possess a dispersion relation, defined mathematically as ω = g(k), where phase velocity (V_p) and group velocity (V_g) are derived from this relationship. The key takeaway is that while V=fλ describes a specific case, it does not encompass the broader implications of dispersion in wave mechanics.
  • Understanding of wave mechanics and properties of waves
  • Familiarity with mathematical expressions of wave relationships
  • Knowledge of phase velocity and group velocity concepts
  • Basic grasp of angular frequency (ω) and wave number (k)
  • Research the mathematical derivation of dispersion relations in various wave types
  • Explore the differences between phase velocity and group velocity in dispersive media
  • Study the implications of non-dispersive vs. dispersive waves in practical applications
  • Learn about the role of medium properties in determining wave behavior
Physicists, wave mechanics students, and engineers interested in understanding wave behavior, dispersion relations, and their applications in various fields such as acoustics and optics.
parsec
Why is V=fl a "dispersion relationship"?
I've heard of V=fλ being referred to as "the simplest dispersion relationship", however it seems to be used to describe non dispersive traveling and standing waves, where the wave velocity is determined by the medium (fixed) and either f is a dependent variable (and λ independent), or vice versa. Is it correct to call this a dispersion relationship in this context?
For example, in sound, V is constrained by the properties of the gas. The frequency of excitation is set by the source (this could be considered the dependent variable), and the wavelength (indep var) is determined by the wave velocity and frequency.
Standing waves seem to have a constrained wave velocity and fixed wavelength, which selects the frequency (independent variable) when excited (by some broadband excitation like a string being plucked or a closed pipe being tapped).
Is there a situation where a wave is governed by the V=fλ relationship, and the velocity is the independent variable. For example, a wave that has both its frequency and wavelength determined by the physical excitation mechanism that then seeks an appropriate wave velocity?
It is a dispersion equation in the same sense as ##y=x## is a quadratic equation, since ##y=0x^2+x## is indeed a quadratic.
A dispersion relation is an expression that relates the frequency of a wave to its wave length. We often deal with angular frequency \omega = 2\pi f and wave number k = 2\pi / \lambda.
Mathematically a dispersion relation is a equation of the form
\omega = g(k)
The phase velocity of the wave is
V_p=\frac {\omega} {k} = \frac {g(k)}{k}
and the group velocity of the wave is
V_g=\frac{\partial \omega} {\partial k} = \frac{\partial g(k)} {\partial k}
If the phase velocity depends on the wave number, then the wave is dispersive. But all waves have a dispersion relation.
  • · Replies 64 ·
31K
  • · Replies 21 ·
