Why isn't linear momentum conserved?
In the discussion regarding the conservation of momentum during an elastic collision between a ball of mass m and a pinned uniform rod of mass 2m, it is established that angular momentum is conserved while linear momentum is not. The pin at the center of the rod exerts an external force, preventing the conservation of linear momentum. The conservation of angular momentum is valid as there are no external torques acting on the system. The correct answer to the question posed is D, indicating that both angular momentum and kinetic energy are conserved.
  • Understanding of elastic collisions
  • Knowledge of angular momentum and linear momentum concepts
  • Familiarity with external forces and their impact on momentum conservation
  • Basic principles of rigid body dynamics
  • Study the principles of elastic collisions in detail
  • Learn about the conditions for conservation of angular momentum
  • Explore the effects of external forces on linear momentum
  • Investigate rigid body dynamics and the role of fixed pivots
Physics students, educators, and anyone interested in understanding the principles of momentum conservation in collisions, particularly in systems involving external forces and rigid bodies.
IntegrateMe
A ball of mass m elastically collides with a uniform rod of length L and mass 2m that is pinned at its center.
Which is/are conserved?
A. Angular Momentum
B. Linear Momentum
C. Kinetic Energy
D. A/C
E. All
The answer is D. Can someone explain why angular momentum is conserved and linear momentum isn't?
Because the momentum of whatever the rod is pinned to (say the earth) is being ignored. The pin applies a force to something that isn't included as part of the problem statement.
Sorry, I may have an incorrect understanding of what exactly the linear momentum and angular momentum of a system are. Do you mind briefly explaining those as well?
What does A/C mean? o.O
angular momentum is always conserve for collisions that do not involve external torques (i remembered my prof and tiny-tim saying something like that )
so the angular momentum of the horizontally moving ball, with respect to say the center of the rod , will be conserved as the angular momentum of the rod rotating as a result of the impact.
since the rod is pinned at the center, it has no translational movement, i.e it can't move horizontally. thus if the ball has linear momentum ( horizontal), then it will not be conserved because the rod doesn't move horizontally, its center of mass is fixed.
A/C means option A and C are correct :D
The linear momentum of a system is conserved if there are no external forces acting on the system. Since the pin exerts a force on the rod during the collision, linear momentum is not conserved.
Or ... you could consider the pin-plus-Earth as another rigid body that is part of the system -- as rcgldr suggested -- then linear momentum is conserved, however the momentum of Earth has not been included in calculating the momentum of the system.
  • · Replies 18 ·
  • · Replies 62 ·
13K
16K
  • · Replies 71 ·
