Mentor
- 37,295
- 16,428
Everything that you have written thus far appears to be a completely standard hidden variable.lukephysics said:I am not sure what I am proposing can be said to be hidden variables. So it might be exempt from bell.
You are incorrect. The wave function absolutely does change. That is what Schrödinger’s equation describes: the way that any wavefunction changes over time.lukephysics said:Can you clarify if I am correct that the wave function of an entangled particle pair does not change as you move them apart in spacetime?
This is exactly the sort of hidden information channel that Bell envisioned.lukephysics said:a hidden QM machine can simulate the collapse of that exact entangled wave function at time of entanglement, bring that result with each particle so that they collapse according to that result when the time comes.
Note that there is some additional constraint here that you may not be considering. The measurement to be performed can be selected after the entangled state is prepared. So whatever information is stored by the simulation cannot depend on which of all possible measurements will be done. It must be a generic piece of information that will correctly produce the results of any possible measurement.
Again, this is false. There is an unavoidable experimental signature of any local hidden variable.lukephysics said:so in this set up an experimenter would never be able to know whether the result was determined by a QM simulation at entanglement or at measurement via spooky action at a distance.
