Why it's easier to push the door from the furthest distance
The discussion centers on the mechanics of pushing a door from various distances relative to its pivot point. It establishes that the torque (τ) required to open or close the door remains constant, but the force (F) applied and the distance (r) from the pivot point are inversely related. Pushing the door from a greater distance increases the torque, making it easier to operate. The analogy of a lever and mechanical advantage is emphasized, illustrating that greater distance spreads the effort over a larger area, akin to using a gentle ramp instead of stairs.
  • Understanding of torque (τ) and its formula: τ = F * r
  • Basic knowledge of mechanical advantage concepts
  • Familiarity with lever mechanics
  • Awareness of force and distance relationships in physics
  • Research the principles of levers and mechanical advantage in physics
  • Explore real-world applications of torque in engineering
  • Study the effects of distance on force in various mechanical systems
  • Learn about the implications of torque in everyday tasks and machinery
Students studying physics, mechanical engineers, and anyone interested in understanding the principles of force and motion in practical applications.
THP
Why it's easier to push the door from the furthest distance From the pivot point?
Is this a homework question?
Nope
Try to to think about this: if you want to open/close a door, you have to make the door rotating about the pivot point ##\longrightarrow## you create a torque. The minimum torque ##\tau_m## to open\close the door is equal if you push near or far from the pivot point. So, if ##\tau_m## is constant for each point you push the door, something, like ##r## (distance from the pivot point) and ##F## (the force applied by you), change. In what way?
Another way to say what 'Bestfrog' said,
when you are trying to close a door you produce torque
the torque formula is defined by T = F (the force you make) * d (the distance from the point where the door is atached to the wall, the 'pivot point')
so, the further you push the door from its pivot point, the greater the torque and easier it is to close / open it
(hope you understood it, otherwise just send more questions - this is my first time trying to answer something :) )
I suspect that an argument based on torque does not provide the intuitive explanation that is sought.
Perhaps a more natural way is to think in terms of mechanical advantage. It is effectively a lever. When you push at a point far from the pivot you have to push further to get the door to close to the same extent. This spreads the effort over a greater distance. It is like walking up the long but gentle ramp instead of climbing the short flight of stairs.
"It is like walking up the long but gentle ramp instead of climbing the short flight of stairs."
Very nice way to explain, thanks for the reply man :)
  • · Replies 52 ·
14K
