Why mass of spring/string assumed negligible?
  • Context: Undergrad
  • Thread starter Thread starter cyt91
    Mass
The discussion revolves around the assumption of negligible mass for springs, strings, or ropes in tension calculations. Participants explore the implications of this assumption on the uniformity of tension and the complexity of related calculations.
  • Technical explanation, Conceptual clarification, Debate/contested
  • One participant questions why the mass of springs/strings/ropes is often considered insignificant, seeking clarity on its effect on tension.
  • Another participant states that if the spring/string/rope is massless, the tension remains uniform throughout, suggesting that including mass complicates the problem.
  • It is noted that if the string has mass, it would also experience acceleration, necessitating the application of F=Ma for the string itself.
  • A participant inquires about the extent of complications that arise when considering mass in these calculations.
  • One response suggests that the inclusion of mass could lead to differential equations that are either significantly more complex or require numerical solutions, contrasting this with simpler solutions involving massless springs.
Participants express differing views on the implications of including mass in tension calculations, with some arguing for the simplicity of massless models while others acknowledge the complexities introduced by mass.
The discussion does not resolve the assumptions regarding the mass of springs/strings/ropes or the specific conditions under which these assumptions hold. The limitations of the models and the mathematical complexities are acknowledged but not fully explored.
cyt91
In most questions I have encountered involving the calculation of tension in spring/string/rope, we are often asked to assume that the mass of the spring/string/rope to be insignificant. Why is this so? What effect does the mass of the spring/string/rope has on the tension of the spring/string/rope? I checked a few A-level books,none offered any satisfactory explanation.
If the spring/string/rope is massless, then the tension is uniform throughout. (Otherwise, problems become too complicated.)
Also, if the string had mass then it would also have an acceleration when it is connected to a system. You would then be needed to write the F=Ma equation for the string also.
If you don't mind me asking, just how complicated things can be?
I think you'd get a differential equation that either:
1. is much more difficult to solve, or
2. can only be solved numerically (in current practice, with a computer)
With massless springs, it's just sines and cosines.
  • · Replies 19 ·
16K
  • · Replies 131 ·
9K
