Why must an ensemble have uniform probability distribution at equilibrium?
231 replies · 20K views
stevendaryl said:
I don't know why it doesn't make sense to you, but everybody has his own limitations.
Because fictitious systems cannot be measured! The measurement result on a single system must be a property of the single system, and cannot depend on properties of imagined copies.
You're getting confused. The measurement result is not an expectation. I'm talking about the relationship between the measurement result and the theoretically computed expectation value.
stevendaryl said:
Okay, what does it mean, in practice, to say that a thermodynamic quantity [itex]A[/itex] has expectation [itex]\langle A \rangle[/itex]?
I gave the link stating the precise meaning repeatedly in this discussion, last in post #164.
In a slightly fuzzy (but still fully correct) version, one can say one can measure (in principle) ##\langle A \rangle## with a negligible uncertainty if the system is large enough. There is no uncertainty at all in the thermodynamic limit that is usually invoked when deriving thermodynamics from statistical mechanics.
The question isn't how to CALCULATE expectation value, the question is, what is the physical significance of saying that the expectation value of [itex]A[/itex] is [itex]\langle A \rangle[/itex]? A physical theory has two parts: one is mathematical, which tells you how to compute various quantities, and the second is observational, which is how those quantities relate to our observations. I'm asking about the second.
What was it exactly that you claimed? Did you mean to say no more than that the theoretically computed value is the average over an ensemble of similar systems? This does not give any relation to a measurement result, it only relates a theoretical value to other theoretical values. Moreover, the theoretical value depends on which ensemble you use to define which systems are similar. Each time I get a different result. Which one is the one related to the measurement?
Hence your proposed relationship amounts to nothing. (One has the same problem with classical probability: The probability to get lung cancer depends a lot on whether you choose the ensemble of all people or the ensemble of all heavy smokers. Which one is the correct theoretical probability? And how do you check it on a particular person who didn't get lung cancer?)
That's what your definition of "expectation value" does.
I was answering the second. The observation gives approximately the expectation, with an uncertainty given by the standard deviation. No probabilities are involved in either asserting or checking this. Why do we have all the error bars in scientific reports on measurements?
But it doesn't. You're not going to get the expectation.
Then what does "You will get [itex]\langle A \rangle[/itex] with uncertainty [itex]\delta A[/itex]" mean? What does it mean that the uncertainty is [itex]\delta A[/itex]?
It doesn't mean that you will get a value between [itex]\langle A \rangle - \delta A[/itex] and [itex]\langle A \rangle + \delta A[/itex]. So you haven't actually connected the theoretical result with observations.
I didn't claim I would. If you are measuring the diagonal of a square of side 1 you are also not getting ##\sqrt{2}##.
It means that with high quality measurement equipment, the difference is bounded by a small multiple (typically less than 3, but 5 in case you want to have very high confidence) of the uncertainty. If this is not the case you expect to have an error in either the prediction procedure, or the experimental setting, or the numerical evaluation of the measurement protocol. (Or you try to publish your result as a failure of the laws of quantum mechanics. But it is unlikely your paper will be accepted unless others can reproduce your result.)
It means that the difference is bounded by a small multiple (typically less than 3, in case you want to have very high conficence) 5 of the uncertainty.
But that's not actually true. The fact that the expectation value of [itex]A[/itex] is [itex]\langle A \rangle[/itex] and that the standard deviation is [itex]\delta A[/itex] doesn't actually imply that my measurement will be between [itex]\langle A \rangle - \delta A[/itex] and [itex]\langle A \rangle + \delta A[/itex]. So what does it imply?
Again I did not claim that. Why do you object to things I didn't say?
What you said was "The observation gives approximately the expectation, with an uncertainty given by the standard deviation". But that has two additional undefined terms in it: "approximately" and "uncertainty". How do you make sense of those two words, in a non-circular way?
Your claim that expectation is less problematic than probability is just false.
By assuming that my readers understand English.
It is impossible to give definitions in which every word used is defined as well. You can't define anything at all in this way. I place the residual uncertainty in my definition in the location where they actual are when people are doing experiments.
But the usual interpretations of "uncertainty" and "approximately" are subjective. So your move from "probabilities" to "expectations" doesn't actually accomplish anything, as far as making the subject less problematic.
Not more than language in general. In spite of this subjectivity, people have a good (though also subjective) sense of what objectivity means.
The purpose of objectivity is to enable a group of cooperative people called scientists to arrive at a reliable, objective, and hence predictive consensus. Not to make everything look unambiguous and logically 100.0000000000000...% correct to nitpickers like you.
It seems to me that you are just hiding problems under the rug. You don't like probability, because it's so subjective, so you replace it by expectation, which is subjective in the exact same sense.
There are standardization efforts to reduce even this amount of subjectiveness. See, e.g., the "Guide to the Expression of Uncertainty in Measurement" (GUM) published by ISO, the National Institute for Standards and Technology (NIST) Technical Note 1297, "Guidelines for Evaluating and Expressing the Uncertainty of NIST Measurement Results", and the Eurachem/Citac publication "Quantifying Uncertainty in Analytical Measurement".
But as you can see from these documents, every attempt to define something accurately results only in much more voluminous explanations using even more undefined words.
Language, and hence science is therefore intrinsically circular. But this benign form of circularity doesn't matter.
The standard practice is to state your assumptions in as clear terms as possible (using standard language without defining it) and start from there. Expectation (using ''approximate'' and ''small multiple'' as self-explained words in terms of which uncertainty is definable precisely) is a far better starting point than betting - which in science is completely hypothetical.
It is not the same sense. Every child can interpret ''a small multiple, typically 3 or 5'', which is used in my explication of approximate, uncertain, and expectation, while probability is a fairly confusing concept even for adults, as the story with the 3 doors demonstrates.
Only under the rug of common language (for simple phrases like ''a small multiple") where everyone hides stuff since it is already full of philosophical problems. But common language is necessary to do any kind of science.
Whereas subjective probability (the rug where you are hiding the problems under) is another can of worms involving additional, much more severe philosophical problems.
whereas I interpreted both very carefully in terms of the only undefined notion of ''a small multiple, typically 3 or 5'', which I can assume to be understood by everybody.
A. Neumaier said:
The Hamiltonian H is invariant in time, hence does not fluctuate at all.
In QM, fluctuation is not a random change with time. Fluctuation is just another name for uncertainty. So the Hamiltonian fluctuates in any state which is not an eigenstate of ##H##.
A. Neumaier said:
Apply in the sense that statistical mechanics applies to a single glass of water. One uses ensemble expectation values for the single quantum system [and, according to Gibbs, nonphysical, imagined repetitions to justify the ensemble language for the single use case] to assign a temperature and other things that can be measured.
Single, nonrepeated measurements of temperature, pressure and volume can be used to check the predictions of quantum mechanics in equilibrium. These measurements have nothing to do with any of the mock measurements of identically prepared systems discussed in the traditional interpretations of quantum mechanics.
The single glass of water is described by thermodynamic quantities like temperature and pressure. If you measure its temperature you have to put a thermometer for a sufficiently long time into the water. Then the thermometer equilibrates with the water, and you can read off a temperature, which is a time-averaged kinetic energy per particle. Also when looking at macroscopic quantities of a single system these macroscopic quantities are averaged (in this case over time) microscopic quantities. The thermometer as a measurement apparatus doesn't resolve the thermal (and quantum) fluctuations of energy, and thus averages out these fluctuations delivering a macroscopic quantity we define as temperature.
True, but this doesn't conform with stevendaryl's use of the term, which I was using in the discussion with him.
Yes; you make my point: Compare your description with what the quantum mechanics 1 postulates claim a measurement of a quantum system is.
vanhees71 said:
If not in a stationary state, there are also quantum fluctuations of quantities in time, right?
##H## is time invariant, hence doesn't fluctuate in time, no matter which state is considered. It is also translation invariant, hence doesn't fluctuate in space. Thus fluctuations have neither a dynamic nor a spatial meaning - the term is used in the same figurative way as vacuum fluctuations in a vacuum whose particle number is zero at all times and everywhere.
