Why must operators map Hilbert space vectors to Hilbert space vectors?
59 replies · 9K views
gaiussheh
This question is closely related to my previous thread mentioning that a linear operator can map a ket out of the original Hilbert space. That example was about infinite squares well, so it may be seen as an artificial example. More recently, I came up with a more "natural" example that does not involve any potential at all.
Consider a wave function ##\psi[x]=\frac{1}{\sqrt{1+|x|^3}}##. It is surely integrable, ##\displaystyle \psi[x]=\int \frac{\mathrm{d} x}{1+|x|^3}<+\infty##. With the position operator ##x## on it, one have ##\displaystyle x\psi[x]=\frac{x}{\sqrt{1+|x|^3}}##, which is not in the Hilbert space anymore ##\displaystyle \int \frac{x^2\mathrm{d} x}{1+|x|^3}=+\infty##. In this example, it seems that ##\psi## is not in the domain of the position operator. I find this explanation somewhat funny as it was telling me that its position is no longer obseravle. This can't be right. You can integrate ##\displaystyle \langle x \rangle = \int \psi^* x \psi \mathrm{d} x = \int \frac{x\mathrm{d} x}{1+|x|^3} ## and the integration is regular.
I just wonder why QM requires the result of an operator acting on a ket always be a ket, and for this sake even kicking some very regular states out of the domain of the operator.
Reply
That's simply not a valid wave function. Square integrability is not sufficient.
An operator on the set of square integrable functions must produce a square integrable function. If it does not, then it is not an operator on that Hilbert space.
You must respect the mathematical definitions.
Reply
The mathematics on which QM is based demands it.
Reply
You are missing the point that an operator need not be defined on the hole space, but just on a dense subspace. Look up unbounded operators.
Reply
I think the real issue here is that the original wave function is not physically viable. The space of physically viable wave-functions needs stronger criteria than being square integrable. Essentially, a wavefunction must tend to zero faster than any power of ##x## as ##|x| \to \infty##. It's generally assumed that there is some subspace of the square integrable functions that meets the criteria of being physically viable. And, as Griffiths puts it, "any good math major" can find exceptions. I don't think this can be a dense subspace of ##L^2##. It must be strictly smaller than that.
Note that the function in the OP has an unbounded first derivative - which is also not a viable property.
The difference for the original question in the previous thread is that the boundary conditions for the infinite square well prevent the momentum operator from being well-defined on the space of possible wavefunctions. This makes the infinite square well a physically impossible system - much like an infinite uniformly charged wire or plate is ultimately physically impossible, even if we can usefully study it.
Reply
The Schwartz space is dense in the ##L^2## space.
Reply
I don't understand why you "guess around" in this case, where there is a well developped mathematical theory, which is not overly complicated and reasonably easy to understand. And which seems quite appropriate for the physical situations that it does cover (i.e. I exclude QFT here).
Reply
What is the exact definition of the Hilbert space and the set of operators that are relevant to QM?
We use a Hilbert space ##\mathcal{H}## to model all possible states of a system*. However we model a measurement - from the highly specific (PVM and the projection postulate) to the highly generalized (quantum instruments) - the state of the system after measurement should be in the same space, as it is a space of all possible states.
There might be a further generalization that relaxes this condition if papers like this are to be believed.
* Really we want the space ##\Sigma (\mathcal{H})## of both pure and mixed states.
Reply
To answer this probably requires an insight article. But like @martinbn stated both the position and momentum operators are unbounded and need special care in handling their domains. This is discussed in detail in Brian Hall's book.
Reply
I wonder why one should exclude this wavefunction simply for this reason - It seems I can talk about ##\langle x | \psi \rangle^2## as the probability (density) of measurement outcome ##x##, I can get ##\langle x \rangle## out of ##\langle x | x|\psi \rangle##, I can measure it energy ##\langle x |\hat{H}|\psi \rangle## and momentum ##\langle x |\mathrm{i}\hbar \partial_x|\psi \rangle##. Everything is well-defined. In any sense, you can't directly feel the wavefunction but only approach it with measurements, and it seems there's nothing stopping me from measuring it, and the wavefunction feels very real.
QM does not restrict operators in that way. It probably cannot restrict them even if it wanted, because otherwise the canonical commutation relation could no longer be realized. So operators are allowed to be unbounded.
The next question could be why only square integrable wavefunction are allowed, instead of arbitrary locally nice functions or even tempered distributions (i.e. elements of the dual of the Schwartz space). This is because they cannot be normed otherwise, so you wouldn't be able to define probabilities. But don't worry if the solution to some concrete problem should turn out to not be square integrable: All you need to do is form wavepackets of such "forbidden" functions to get back some square integrable function. Then you take the limit of an arbitrary sharp wavepacket, and basically go with the forbidden solution anyway.
Reply
  • Skeptical
This is mathematical hocus pocus!
Reply
I think PVM is actually not stopping me from talking about position measurement outcomes (and associated probabilities) of my (strange) example ##\langle\psi|E_{\Omega}|\psi\rangle##? However, the operator refuses to act on it.
The problem with the wavefunction is that it doesn't tend to zero fast enough. So, it can't be associated with a realistic physical system. That's the simplest answer to this dilemma. You could try to calculate the expected momentum or kinetic energy of a particle with that wavefunction. If the integral diverges, then something is wrong.
That the position and momentum operators have unphysical eigenfunctions is a further issue. That's not the same issue as you have here. That issue is resolved by the theory of "rigged" Hilbert spaces and functions that are distributions.
Reply
It was not my intention to create even more confusion by "mathematical hocus pocus".
I had the impression that you seriously confused @gaiussheh now, so I decided to tell him some of the mathematical background. He can still decide for himself whether this makes everything even more confusing, or whether it becomes more plausible und understandable.
Not sure if I am confusing you! I am not talking about the form of the operator but the domain. I mean, QM always wants to pick a subspace of the Hilbert space such that an operator always maps a square-integrable function to a square-integrable function. Why is this necessary? I can always compute ##\displaystyle \int \psi^*[x] x \psi[x] \mathrm{d} x##, however if ##\psi## is not in the domain then since ##x |\psi\rangle## is not a vector in the Hilbert space the inner product ##\langle \psi | x |\psi \rangle## is not readily defined, but can only be seen as a short-hand notation of the former?
It is not necessary. What is actually necessary is that the operator is self-adjoint.
My guess is that the inner product ##\langle \psi | x |\psi \rangle## can be defined on the space of square integrable functions (i.e. ##L^2##), but I would have to look-up the details. (And if the integral should happen to be defined too, then one should be able to show that its value coincides with that definition.) The operator ##x## itself can be defined on the space of tempered distributions by transposition, whenever the operator ##x## is defined on the Schwartz space. (And it is precisely for that case that I believe that your inner product can be defined on ##L^2##.)
Reply
I'm not sure it can, or that it needs to be. The operator under discussion is not physically realizable: it corresponds to an infinitely precise measurement of position, which is not possible. Any real measurement has some finite error. So the operator ##\hat{x}## is not what we are actually realizing physically when we "measure the position" of something; we are realizing some other operator, which would be much more complicated to write down explictly, but which basically corresponds to measuring the position to within some finite error bar.
The reason the operator ##\hat{x}## is often discussed in textbooks, even though it's not physically realizable, is that, with appropriate mathematical tools, it's easy to work with, and it's easy to understand what it's doing. That makes it suitable for pedagogy, at least to many textbook authors, even though it's useless for practical experiments.
Reply
Quantum mechanics is more than a handful of seemingly relevant quantities. Consider the following thought experiment. Given a quantum system, one should be able to perform a measurement corresponding to an operator ##A## and then perform a subsequent measurement on the same system corresponding to another operator ##B##. However, if the operator ##A## maps the state to some other Hilbert space ##\mathcal B## or even outside of Hilbert space, then it is not possible to perform the subsequent measurement corresponding to ##B## given that ##B## is only defined on ##\mathcal H##. Thus, when working with a given system whose state is in ##\mathcal H##, all the relevant operators must be definable on ##\mathcal H##. So given a set of relevant operators, one must exclude functions which are not mapped from ##\mathcal H\rightarrow\mathcal H##.
Reply
The problem with functions like the one in the OP is that the inner product involving the operator ##\hat x ^2## is not defined (even if the integral is finite for the operator ##\hat x##). This is why the function must eventually decay like a Gaussian - i.e. faster than any power of ##x##.
Eventually the mathematical theory that supports QM gets murky and goes beyond what would be taught in a linear algebra/functional analysis class. All I was really trying to say, however, is that the initial lesson to learn is that not all functions in ##L^2## are possible wavefunctions and we must be dealing with a subspace of ##L^2##. Not least, because there are "pathological" functions in ##L^2## that would not submit to much of the theory of QM. This is true of physics more generally - it can assume that functions are "well-behaved" - and anything else can be excluded on the grounds of being "unphysical".
My point is simply that if you try to include all the functions in ##L^2## in a physical theory like QM, then you are going to come unstuck.
One final mathematical point. We can study linear operators from one Hilbert Space to another: ##T: \mathcal{H_1} \to \mathcal{H_2}##. But, we don't have the operation of functional composition. Whereas, when we study linear operators from a fixed Hilbert space into itself, we can compose operators:
If ##T_1, T_2: \mathcal{H} \to \mathcal{H}##, then ##T = T_1 \circ T_2##, defined by ##T(\psi) = T_1(T_2(\psi))## is a linear operator from ##\mathcal{H} \to \mathcal{H}##.
The property of operator composition underpins much of the theory used in QM and means that you can't consider operators that map functions into a larger Hilbert space.
It ensures that the inner product that you need to compute is finite by Cauchy-Schwartz. It is also needed if you want to do more than one measurement in succession . If the image of the ket is not another ket, how do you apply an operator to it!
Reply
My concern on this is that even if you have a wavefunction like ##\mathrm{e}^{-x^2}##, you can still construct ##\hat{O}=\mathrm{e}^{x^2}##, and again your wave function got kicked outside by this operator. Once you start to constrain the behaviour of operators, it becomes a rabbit hole, and you end up with a specific theory instead of a theory for any self-adjoint operator.
This is not an operator. You cannot just pick a function and say multiplying by it is an operator.
What is the definition of operator that you use?
Reply
The problem, as highlighted by @martinbn above, is that you are trying to build without proper mathematical foundations. Self-adjoint has no meaning outside of precise, well-defined functional analysis.
I think his question is more basic than this. He asks if an operator sends vectors from one space to the same space. And I think the problem may be the text he uses. If it is a QM textbook, then there will be a lot to grok and a lot left out as they do in physics.
I understand that. An operator more generally can map vectors from one space into another. But, whether the text book says so explicitly or not, QM uses operators than map vectors from one space into the same space.
For example, in Modern QM by Sakurai (who is definitely not the most rigorous), he says explicitly that an operator maps a ket to a ket. This should be quite clear.
Further to the points above, this requirement is essential for the composition (multiplication) of operators, which is essential for the fundamental commutation relations.
You cannot get started with QM without having a single, fixed Hilbert Space (for each system in question) on which you can study operator commutation.
This is all on pages 12-16 of Sakurai.
Reply
Well, that is actually where my confusion starts. I take an operator to be a map from a function to a function. It may not be closure in the Hilbert space, so people usually restrict its domain to, for example, the Schartz space. I just do not understand the rationale behind this. As long as your function decays faster than ##\mathrm{e}^{-x^2}##, in integrate ##\displaystyle \int f[x] \mathrm{e}^{-x^2} g[x] \mathrm{d} x## converge and it is still self adjoint. So, similar to restricting wavefunctions to the Schwartz space, you can say that the operator ##\mathrm{e}^{-x^2}## has a smaller domain and is still self-adjoint. This never comes to an end, so why would one ever do this at the beginning?
