Why must volume charge density be zero where E is uniform?
8 replies · 5K views
Lola Luck
[/B]
a) In a certain region of space, the volume charge density p has a uniform positive value. Can E be uniform in this region? Explain.
b) Suppose that in this region of uniform positive p there is a "bubble" within which p=0. Can E be uniform within this bubble? Explain.
E = electric field
Gauss's law: Flux= ∫ E dA = Q/ε0
I thought that if the volume charge density p were uniform, E would also be uniform because the charge enclosed by a Gaussian surface would be the same everywhere. However my book says that in a region where "the electric field E is uniform... the volume charge density p must be 0."
Do you know Gauss law in the differential form? That is, with the divergence theorem?
If yes: This says that ##\nabla \cdot E = \rho / \epsilon_o## in which case, a uniform E has no divergence, and therefore zero density.
If no: Uniform fields give no flux. You know as a fact that enclosed charges give flux. If you have flux, then the field isn't uniform.
If you wish for something intuitive tell me and I'll try to make something up.
Lola Luck said:
[/B]
E = electric field
For part (a):
Ask yourself a related question. Suppose that in some region of space the electric field, E, is uniform . What is ##\displaystyle \oint \vec{E}\cdot d\vec{A}## in that region?
Sorry for the late response.
I guess I didn't realize that if there's flux the field isn't uniform, but it makes sense. Thank you.
SammyS said:
For part (a):
If E is constant, that integral would equal the product (E)(area). So there's a positive flux, which implies that that region isn't uniform.
Yes, but that's a closed surface, so if ## \vec{E} ## is constant (in both magnitude and direction), then the flux inward is equal to the flux outward. That's a net flux of zero out of the surface.
I see, so when ## \vec{E} ## is constant there can't be any enclosed charge.
That's correct.
