Why Negative Hydrogen/Deuterium Ion Generators?
Negative Hydrogen and Deuterium Ion Generators are essential for producing neutral beams of hydrogen and deuterium for fusion applications. These generators utilize negative ions, which can be easily stripped of their extra electron, allowing for high neutralization efficiency. The low binding energy of the captured electron, approximately 0.75 eV, facilitates this process. Relevant literature includes FermiLab's work on negative hydrogen ion sources and IAEA's research on ion sources.
  • Understanding of negative ion generation techniques
  • Familiarity with fusion technology and neutral beam injection
  • Knowledge of ion source applications in particle accelerators
  • Basic principles of electron affinity in ionized gases
  • Research "neutral beam injection" techniques and applications
  • Study "negative ion sources" in particle accelerators
  • Explore the principles of "electron affinity" in ionized gases
  • Review the FermiLab and IAEA publications on ion sources
Researchers in fusion technology, engineers working with particle accelerators, and professionals interested in advanced ion generation methods will benefit from this discussion.
Chorlton
Auto-Search gives me some hints.
I did a Google for "Hydrogen Ion Generator" and got a load of hits about "Negative Hydrogen Ion Generators". They almost seem to be 'fusion specific'. Are they used because the required end result is a neutral beam of Hydrogen/Deuterium for injection into the fusion chamber and the negative ions can be accelerated with the extra electron being easily stripped off before injection?
Negative ion sources are also used with accelerators.
One author puts it: "The electron captured in the negative ion has a very low binding energy called affinity of Ea = 0.75 eV. Ion can easily lose the electron and become neutral, and this is a reason why a high neutralisation efficiency can be achieved with negative ions."
Ref: http://mafija.fmf.uni-lj.si/seminar/files/2004_2005/NBI1.pdf
Some discussion in the following papers:
FermiLab - Negative Hydrogen Ion Sources for Accelerators
IAEA - Ion Sources
One can also search on "neutral beam injection".
  • · Replies 0 ·
  • · Replies 19 ·
