Stormer
- Messages
- 121
- Reaction score
- 23
Positive displacement pumps are used a lot in the industry for pumping water or other liquids. So why is it not used as turbines in hydropower plants?
I'm not talking about pistons here. More like lobe pumps, gear pumps, gerotor pumps, geroler pumps, screw pumps, and so on. Some of them have very minimal pulsation. And they don't have any reciprocating parts that need counterbalancing. And they can be driven in reverse to function as pumped hydro for intermittent energy like wind and solar to store energy. A Pelton turbine can not do that, but need separate pumps for that function. While a Francis turbine can work in reverse for pumped hydro, but i don't know how efficient it is in this mode?Lnewqban said:Also, the huge flows involved imply big reciprocating parts, with the associated big accelerations and forces, and the need to counterbalance those.
I don't know. I'm just asking a question.anorlunda said:Where would you place existing designs of positive displacement turbines on this diagram?
Here's a calibration. The left hand border of that diagram is a flow of 1 m3 per second. That is 15380 gallons per minute. Most positive displacement pumps operate 1-2 decades to the left of that.Stormer said:But if i would have i guess i would think relatively high head and low flow.
No. There is no sliding contact between the lobes in a lobe pump, or the screws in a screw pump, or between the rotors and the housing in a pump made for liquid applications like water. It is in fact a small clearance between them that is dictated by the viscosity of the fluid it is made to work with. I work as an automation engineer making processing plants for food, farma, water treatment and so on, and we use these positive displacement pumps for water, milk, beer, yoghurt, ketchup, acid, lye, and so on all the time. And the liquid in the pump is not doing any lubricating work. It has a built in clearance made according to the liquid viscosity you specify when the process engineers calculate the pumps needed.Baluncore said:Positive displacement pumps and turbines have fluid chambers with fixed volumes. Therein lies the problem, with the seals between chambers and the surfaces in sliding contact. Gear motors and pumps are positive displacement systems that are almost always lubricated by the fluid they contact, such as hydraulic oil.
We use lobe and screw pumps for example in CIP return pumps to get the dirty cleaning water out of thanks that you are cleaning (because a centrifugal pump would just get air locked all the time in that kind of application). And as i said there is no seals on the rotors of these pumps, just a specified very small clearance. And these work for many decades without any need for maintenance for the lobes or screws (just change the oil in the gearbox after some years, and the bearings in the motors when they start to make noise). As long as you are carefull to flush out any metal shavings from the system from grinding and cutting when the piping is made the pump will work for a very long time. In a turbine application i suppose you would put a filter in front of it to remove any sand or rocks from entering the turbine.Baluncore said:Progressive-cavity-pumps, such as worms, screws, and blowers, are often used with incompressible water, or compressed air. Those engines tend to have elastomer seals that are damaged by fluid contamination. Where inverted for use as motors, they would require higher maintenance, and so would rapidly be replaced by the more reliable flow turbines.
Maybe the food industry is clean. I often see worn pumps from the processing industry, going to scrap.Stormer said:In a turbine application i suppose you would put a filter in front of it to remove any sand or rocks from entering the turbine.
