magnetar
- 83
why positive or negtive polar of battery can not attract small objects ?
The discussion clarifies that the positive and negative poles of a battery do not attract small objects due to the minimal charge present at the terminals. While a battery has a potential difference (e.g., 1.5 V), it lacks sufficient voltage to create a noticeable attraction like a statically charged rod. The battery operates similarly to a capacitor, with its capacitance and dielectric properties affecting the force exerted on nearby objects, which remains negligible. The internal electric field generated by the battery is insufficient to attract small particles significantly.
PREREQUISITESStudents and professionals in physics, electrical engineering, and anyone interested in the principles of electrostatics and battery functionality.
supratim1 said:you tell me why do you think it should?
rcgldr said:It's because a normal battery doesn't have enough voltage to attract small objects like a statically charged rod with high voltage.
rcgldr said:I didn't realize you meant static related attraction. It's because a normal battery doesn't have enough voltage to attract small objects like a statically charged rod with high voltage.
Assuming a moderate amount of capacitance, then a high voltage battery (if such a thing exists) would have signicant charge on at least at one of it's terminals. As mentioned above, batteries do attract dust.tiny-tim said:Voltage is relative.
and this causes magnetic field?supratim1 said:Most batteries are electrochemical cells, with voltage controlled by varying the concentration of the ions. the EMF can be calculated using the Nernst equation.
when a conductor connects the two terminals, the electrons get a path to go to a higher potential (which they die to do). the battery creates an electrostatic field outside it, which makes the electrons move.
No one did. What was stated the terminals of a battery have a static charge, relative to the voltage (divided by the equivalent of capacitance) of the battery, and that the static charge is enough to attract dust.torquil said:A battery not in a closed circuit (i.e. without a current running through it) does not create a magnetic field. I don't think anyone claimed that it did?
rcgldr said:No one did. What was stated the terminals of a battery have a static charge, relative to the voltage (divided by the equivalent of capacitance) of the battery, and that the static charge is enough to attract dust.
magnetar said:Because the positive pole accumulate positive charges, it should attract small objects as the charged rubber rod do ?
magnetar said:why positive or negtive polar of battery can not attract small objects ?
