Why rotation apparently seems to be absolute?
  • Level: Graduate
  • Thread starter Sushmit Nandy
82 replies · 3K views · last reply
Dale said:
Brans Dicke gravity has a parameter that represents how Machian the universe is (with lower values being more Machian and GR being the limit as it goes to infinity).
I'm not aware of this interpretation of the parameter in Brans-Dicke theory. It doesn't seem to be mentioned in either MTW or Wald. Do you have a reference that discusses it?
PeterDonis said:
But that's not the kind of rotation the OP is talking about. The OP is talking about rotation of a test object, one whose effect on the spacetime geometry is negligible.
Maybe you misunderstand me.
The OP asks, in effect, why there is an absolute zero wrt rotation. The Berkelian/Machian explanation is that it is determined by the aggregate motion of the mass of the universe. GR frame dragging can explain that and clarifies that this follows an inverse cube law (yes?), but the corollary is that absolute zero rotation can vary from place to place; one observer may perceive another's zero rotation as rotating.
Yes, and the answer is that there is: the vorticity of the congruence of worldlines describing the object.
No, it can't; as I've already pointed out, frame dragging is involved in a different kind of "rotation" from the kind the OP is asking about. As I said, the OP's example is set in flat spacetime, where there is no frame dragging. So frame dragging can't possibly explain why the congruence of worldlines describing the OP's rotating box has nonzero vorticity.
"Perceived" rotation in this sense is coordinate-dependent and is not an absolute. So it's not an answer to the OP's question about absolute rotation. Vorticity is that answer.
I think you need to restate this in terms of actual math. Carefully. There are plenty of pitfalls for the unwary lurking here, and I'm not sure you have considered them.
To be fair, the OP did talk about rotation with respect to "distant stars" as well as "local" rotation that you could detect even if you're unable to get any information from the outside universe (the latter is the kind of rotation that nonzero vorticity is). As I said in post #5, the two senses of "rotation" are not the same and don't necessarily match in relativity. Frame dragging (Lense-Thirring precession) is one of several effects I mentioned in that post that can make them not the same.
But none of this changes the fact that, as I said, there is no frame dragging in flat spacetime, and the OP's scenario was set in flat spacetime, so frame dragging simply can't play any role in explaining whatever the OP wants explained about rotation in that scenario. (The only effect I mentioned in post #5 that can make vorticity not match up with rotation with respect to the "distant stars" in flat spacetime is Thomas precession.)
Demystifier said:
But the thread starter said that he has no background in physics. I understood this thread as a challenge to explain things in an elementary way, at a popular physics level. In fact, I often take such challenges, in spirit of the famous claim often attributed to Einstein, that you don't truly understand things until you can explain it to uneducated people. If, for that reason, I over-trivialized some things, I apologize.
Sir, I am not uneducated. I am not just trained enough in physics.
I would welcome any answer that's accurate, whether it's of graduate level or high-school. So one can answer in whichever way they are comfortable in.
You already have had a number of accurate answers. For example, my answer that the box has nonzero vorticity and the universe has zero vorticity, and that's why the box is showing effects of rotation.
Do you have further questions about the answers you have received?
But sorry to say, I just joined yesterday and today I am being called uneducated. Is this the way common people are treated here ? I am no genius. But why am I being disrespected. I am sorry but someone could have just told me that this is the wrong place for me, and I would have left simply. This is too rude
I'll go through them properly sir, and if I have one, I'll ask over here. I guess I can do it ?
I don't think that remark by @Demystifier was meant as a negative judgment. He was trying to gauge your level of background knowledge in this subject area in order to give you answers that would be helpful to you.
Sushmit Nandy said:
I am being called uneducated. … why am I being disrespected.
He did call you uneducated, but I think it was not intended the way it came out.
Usually here when we ask about someone’s education it is intended to help communicate rather than to disrespect. Every single one of us here was uneducated, and we each needed someone else to adjust their communication for us.
Dale said:
Yeah, that doesn’t sound particularly enjoyable.
So instead of getting involved in nitpicking, I will just point out that many, perhaps most, types of measuring devices were developed before the corresponding theory. So, if you want to allow science to actually happen in the real world instead of just in theory, then you must allow operational definitions in the absence of a theory.
I agree with that. But the thread starter asked a "why" question. "Why" questions can only be answered by theory.
I apologize, I didn't mean it this way. Moreover, I think you are very smart, because you are asking very good questions that well trained (I would say overtrained) physists usually do not ask.
No sir, you need not apologize. You are elder than me and also a teacher, and I always respect elders and teachers. I just wanted to clear it. And sir, I am just an ordinary student of chemical engineering, nothing more
That is simply not true. (Nor is it relevant)
“Why do we accept the postulates of special relativity?” Can and should be answered with experiments.
Demystifier said:
@PeterDonis and @Dale , how to explain the notion of proper acceleration at a popular physics level, to someone without a physics background?
I would concur with the idea that an operational definition is best. In this case, I would suggest that a ring laser gyroscope is the best tool to operationally measure rotation. Actually, it measures the component of rotation along some specific axis, one needs multiple such devices to detect rotation along three different axes to make sure there is no rotation.
We can also point out that such a device must, of necessity, not be pointlike - it needs to have a nonzero area to function.
Then we can say that the sort of rotation measured by a ring laser gyroscope is absolute because it can be experimentally measured by a device, without any reference to an external object or an external reference frame, though one could nitpick about the implications of the need for the device to have nonzero area and whether this implies the existence of a reference frame. I will leave that to others if they wish to do it.
Now we come to the second part, which is a bit harder. It's easy to show that there is a simple device that measures rotation. But how can we prove that there is no such device that measures absolute velocity? We don't imagine that we can or have built all possible devices and done all possible experiments. Instead , we talk about some basic physical principles to show that such a device would violate said basic principles. Hopefuly this is related to the OP's question.
Unfortunately, the concept of symmetry may not be familiar to the OP, I suppose. Saying that the laws of physics don't change with motion is the easiest way of explaining this principle. But I can imagine someone asking "why". Especially if their concept of the laws of physics is entirely based on Newton's three laws. I suppose the easiest thing to point out is that this idea historically goes back to Gallileo, and existed even before Newton formulated his three basic laws. People may not actually be familiar with the details of his work, but usually people are willing to accept that Gallielo and Copernicus are sufficiently authoratative and also not "newfangled" theories like Einstein's. (Of course, at this point, Einstein's theories are over 100 years old). If there are questions, we can find the relevant reference. Specifically, Google finds that the relevant English translation of Gallielo' famous 1632 work, "Dialogue concerning the two chief word systems", translated by Stillman Drake from the original 1632 Italian, is available at https://iiif.library.cmu.edu/file/Posner_Files_520_G15D_1653/Posner_Files_520_G15D_1653.pdf
Now, they might not actually read the whole thing - I know I have not, though it's quite famous. But it seems like a good place to point the curious person at who is interested enough to do the work, and it will do a much better job of explaning than I can, and I suspect it will do a better job than pretty much any short PF post will.
Sir, I didn't get that why are we talking about symmetry here. If you could elaborate, then it would be very helpful. And that absolute velocity cannot be detected, that though I know this is not the rigorous way to put it, but just one can imagine, in a train with all windows closed, translating smoothly, perhaps with 1,00,000 km/s wrt the ground, and I can feel it that no experiment would distinguish it from the situation had it been at rest relative to the ground. I again apologize for this imaginative way, and I know it's not how physics proceeds, but just shared how I think of it. And it would also be great, if you could elaborate, what are those basic principles which would be violated, if a device measuring absolute velocity ever existed. Thank you. Don't know whether continuing such long discussions are allowed or not over here. Open to guidance ....
A symmetry in math or physics means that something under discussion stays unchanged under a particular transformation. The sort of symmetry is usually given as an adjective, for example "rotational symmetry" means that something is unchanged by rotation. Rotation here is an adjective modifying symmetry, to specify what type of symmetry. We might say that "distances on a map" (the something) have "rotational symmetry" (remain unchanged under rotation). It's just the sort of language physicists use.
Yes, this is correct. Physicists just use different language, a jargon. I've tried to explain the jargon a little bit, but you don't absolutely need to know it. It can be helpful to learn the jargon, though. Your long explanation would often be described as saying "the laws of physics on a train" (the something) has a "boost symmetry". Boost is a physicists way of talking about a transformation where we add the same velocity to everything. So it follows the same structure, we have a something of particular interest ("the laws of physics"), and a transformation that leaves this something unchanged (a boost transformation).
There's no need to apologize. Asking questions is a good thing.
I'm not sure I've answered your question, but you do seem to be on the right track with your understanding.
The basic principle here is called the principle of relativity--although it predates by several centuries the theory we call "relativity" today. Galileo in the early 1600s made the basic observation you have made, that as a matter of actual experience we can't tell uniform motion from rest. Ultimately that's where these "basic principles" come from--we see by experience that the universe appears to obey them, and so we try to figure out ways to incorporate them into our theories.
For example, we observe that experiments generally look the same no matter which direction our lab is facing. We incorporate that into our theories as symmetry under rotation. And we observe that experiments generally look the same when done in labs at different places and at different times. We incorporate that into our theories as symmetry under translation in space and time. Here "symmetry" just means the laws of physics we write down look the same when we apply those transformations mathematically.
