Why Sea Level sometimes gives an illusion being at height
The discussion revolves around the phenomenon where sea level appears to give an illusion of being at a height, particularly when driving down a mountain. Participants explore various explanations for this visual perception, considering factors such as perspective, sensory perception, and environmental conditions.
- Exploratory
- Conceptual clarification
- Debate/contested
- Some participants suggest that the illusion arises because the viewer's gaze is directed downward, making the horizon appear higher than when viewed at eye level.
- Others argue that the spherical nature of the Earth contributes to the perception of height, as the curvature affects visual cues.
- One participant mentions that human senses are adapted for ground-level perception, leading to sensory illusions when driving down a mountain.
- There are references to visual phenomena such as the somatogravic illusion, which can affect how we perceive our orientation.
- Some participants note that environmental factors, like temperature inversions, could create mirages that alter the appearance of the horizon.
- Examples are provided of other visual illusions, such as streams and canals appearing to flow uphill, which may relate to the discussion's theme.
- Questions are raised about the definition of sea level and how it relates to one's position, especially when standing at the water's edge.
- There is a discussion about perspective and inclination affecting visual perception, with references to the original post's image.
Participants express a variety of viewpoints, and no consensus is reached regarding the primary cause of the perceived height illusion. Multiple competing explanations are presented, reflecting differing interpretations of sensory perception and environmental influences.
Limitations include the reliance on subjective visual experiences and the potential influence of individual sensory adaptations. The discussion also touches on the complexities of defining "level" in relation to the Earth's curvature.
- 545
- 147
- 1,092
- 446
BoB
- 13,322
- 4,219
If you are driving down a mountain, then it's not an illusion that you are on a mountain.physicsEnthu_123 said:Why Sea Level sometimes gives you an illusion being at height like a small mountain? Specially when you are driving down of the mountain?
- 5
- 0
- 30,519
- 7,515
Is it not just because our sense of what is actually 'horizontal' is not very well developed? There is really no reason why Evolution would have given us the ability to resolve such small angles. Certainly, nothing that we experience in a smoothly rolling motorcar will be familiar with our basic senses. Let's face it, it was only when Newton came on the scene that people had much idea of such things at all. We get all our clues from what we can see and that's dominated by nearby things.physicsEnthu_123 said:Why Sea Level sometimes gives you an illusion being at height like a small mountain? Specially when you are driving down of the mountain? Please find the attached image to see what I am referring to.
- 10,546
- 2,324
- 10,546
- 2,324
http://aviationknowledge.wikidot.com/aviation:somatogravic-illusion
- 35
- 4
- 30,519
- 7,515
- 3
- 0
Perhaps you can go to the location in Google Earth, make sure vertical exaggeration is 1:1.
Go down to street level in the same location and see if the horizon looks the same.
(I tried to see if I could discover the location from the clues in the image but all I concluded is that you are probably right handed, driving at just over 40 mph and listening to FM 89.5 and located on the West coast of the US driving in a roughly WNW direction in the late afternoon)
- 30,519
- 7,515
But everywhere looks distorted and more or less horizontal. The camera was not designed to give topographical information - just to be wide angle and tolerant of the road slope.Opis said:Go down to street level in the same location
- 5
- 0
You are about right for the location. It is San Diego, Delmar County, I took the exit High bluff drive towards the ocean. Anyways this is what I found on your super mirage theory.Opis said:Clear dry day - possible temperature inversion. That could create a superior mirage and make the horizon look higher than it otherwise would.
http://www.dailymail.co.uk/sciencet...rgana-mirage-hidden-iceberg-Titanic-late.html
I would like to know if there is anyway if I can confirm any of the theories. I will try the suggestions here. I will drive down on weekend again and see. Thanks.
- 3
- 0
32°56'54.48" N 117°15'34.97" W
The Street View image is on a more humid day and the horizon looks just as high if not higher. It is hard to compensate for the (presumed) greater height that the Street View camera took the shot from, and to be sure that the atmospheric conditions are different... but overall I don't think this view supports my suggestion that it was as a result of a mirage.
- 13,322
- 4,219
sophiecentaur said:There are many examples of streams and canals that appear to be running uphill.
And some rivers are actually flowing uphill:
http://physics.stackexchange.com/questions/209805/rivers-that-flow-uphill-due-to-Earth's-rotation
- 30,519
- 7,515
Well well.A.T. said:And some rivers are actually flowing uphill:
But what do you call 'up hill' under those conditions? Could be a moot point.
I have to take issue with "what would happen of the Earth stopped spinning?" part of that article. It takes things in totally the wrong direction, imho. It's just another of those exercises in nonsense scenarios which would involve unbelievable amounts of Energy and Organisation to achieve. They should be throttled at birth, as far as I am concerned.
[Edit: Ye gods - I just re-read this. It sounds far more grumpy than I intended!]
- 4
- 0
How far is it from me?
At 5 km you can still consider the sea level relative to my feet?
That is, 5 km from me, can a point on the surface of the water still be considered sea level relative to my ankles?
- 30,519
- 7,515
The Earth is a Spheroid so any distance away from you, along a tangent will be 'above' the sea. Assuming the UK is about 1000km long and the Earth's radius is 4000km, that means the extremities will be about 30m 'below' a tangent to the mid point. What would you call 'level'? The sea would not flow away from that mid point (ignoring tides and spin etc. etc..deZordine said:If I'm with my feet up to my ankles in the water of the sea, on the water's edge, where is the sea level, exactly where?
- 201
- 197
https://en.wikipedia.org/wiki/Perspective_(graphical)
Also if you take a look at the OP picture, alse every section of the road in front appears higher than it actually is.
I think the post #7 from @CWatters visualizes it best.
- 4
- 0
sophiecentaur said:The Earth is a Spheroid so any distance away from you, along a tangent will be 'above' the sea. Assuming the UK is about 1000km long and the Earth's radius is 4000km, that means the extremities will be about 30m 'below' a tangent to the mid point. What would you call 'level'? The sea would not flow away from that mid point (ignoring tides and spin etc. etc..
Maybe you want to say that if a radius is 4000 km, for a surface of 1000 km, the corners of this surface on the given sphere will be at a difference of about 31,496,588mm, that is 31.49km in front of tangent from the middle of the 1000km circle arc.
That is, 31,496,588mm (31.49 km) distance from both ends to the tangent in the middle of the circle arc.
- 30,519
- 7,515
last night I saw some images of (parallel) ‘sunbeams’, taken with the Sun behind the camera. They appeared to converge towards a point, below the horizon. Seeing is not believing.
- 3,191
- 3,812
sophiecentaur said:Seeing is not believing.
Or, gravitational vortexing?
- 9,504
- 4,758
- 30,519
- 7,515
It's something that GPS uses all the time and the different systems use (so I believe) slightly different curvatures and centres so two ships can end up in different places with the same co ordinates. (Which can be less of a disaster than when two ships hit each other at an agreed rendezvous point when using the same GPS settings.)deZordine said:Maybe you want to say that if a radius is 4000 km, for a surface of 1000 km, the corners of this surface on the given sphere will be at a difference of about 31,496,588mm, that is 31.49km in front of tangent from the middle of the 1000km circle arc.
- 1,249
- 511
CWatters said:There aren't many visual clues to distinguish the difference between the two cases...
Heh heh. There is one big visual clue. There's an ocean there, and you know it's pretty close to level.
But seriously, good drawing.
There is an additional thing going on because you are at altitude. At higher altitude, the horizon is at a larger angle to the near edge of the water. This is both an effect of perspective, and because you can see farther. When the apparent distance to the horizon is larger, your brain wants it to be higher, not farther away. Because you have to raise your eye line more to look at it.
- 16,110
- 8,300
gmax137 said:Or, gravitational vortexing?
Also note Spook Hill in Lake Wales, Florida, where you can stop your car, put it in neutral, and apparently roll uphill.
I've driven near there many times, but have never tried it for myself. Next time I'm in the area I'll check it out!
- · Replies 23 ·
- Replies
- 23
- Views
- 5K
- · Replies 7 ·
- Replies
- 7
- Views
- 3K
- · Replies 1 ·
- Replies
- 1
- Views
- 4K
- · Replies 11 ·
- Replies
- 11
- Views
- 5K
- · Replies 2 ·
- Replies
- 2
- Views
- 2K
- · Replies 7 ·
- Replies
- 7
- Views
- 3K
- Replies
- 1
- Views
- 2K
- · Replies 20 ·
- Replies
- 20
- Views
- 4K
- · Replies 4 ·
- Replies
- 4
- Views
- 2K
- · Replies 2 ·
- Replies
- 2
- Views
- 2K
