Why Set of nxn Matrices w/ Zero Determinant Not Subspace of Mn,n
  • Thread starter Thread starter yanjt
    Subspace
The discussion revolves around the properties of the set of all n*n matrices with a determinant of zero, specifically questioning why this set is not considered a subspace of the vector space of n*n matrices, Mn,n.
  • Participants explore the closure properties of the set under matrix addition and question the implications of the determinant function not being linear. Examples are suggested to illustrate the failure of closure under addition.
The discussion is active, with participants raising questions about the criteria for subspaces and the properties of determinants. Some guidance has been provided regarding the closure under addition, but there is no explicit consensus on the overall understanding of the topic.
Participants express confusion about the criteria for subspaces and the nature of the determinant function, indicating a need for further exploration of these concepts.
yanjt
Hi,
I would like to know why the set of all n*n matrix whose determinant is zero is not a subspace of Mn,n .Can anyone explain the reason for me?
Thanks!
Not closed under matrix addition.
In general, the relation det(a + b) = det(a) + det(b) doesn't hold. Try to think of an example where det(a) = det(b) = 0 but det (a + b) is not equal to zero.
True, but not the point. If det were a linear map then its kernel is a subspace. Its kernel not being a subspace implies det is not a linear map. But that does not mean that its kernel is not a subspace (exercise: find an example of a map f from a vector space to the base field so that f is not linear, but the set of x such that f(x) is zero is a subspace).
Hi, I do not understand why it is not closed under matrix addition.It is still a Mn,n matrix isn't it?
Find two matrices whose det is 0 but whose sum has nonzero det.
But that isn't the only criterion you had to have the sum satisfy, is it?
