Why to change from momentum space integrals to spherical coordinate ones?
The discussion focuses on the transition from momentum space integrals to spherical coordinates in the context of loop contributions to the Higgs boson. Participants clarify that changing momentum integrals to spherical coordinates is a standard procedure in multivariable calculus, specifically expressed as d3p → p2 dp dΩ. The conversation highlights the importance of dimensional regularization and the interpretation of integrals in higher dimensions, particularly emphasizing the volume element of a hypersphere. The integration of dΩ leads to the area of a d-1-dimensional unit sphere, which is crucial for evaluating these integrals.
  • Understanding of dimensional regularization in quantum field theory.
  • Familiarity with multivariable calculus and spherical coordinates.
  • Knowledge of loop integrals in particle physics.
  • Experience with integral evaluation techniques in quantum mechanics.
  • Study the application of dimensional regularization in quantum field theory.
  • Learn about the evaluation of loop integrals using spherical coordinates.
  • Explore the mathematical foundations of hyperspheres and their volume elements.
  • Investigate the integration of angular variables in higher-dimensional spaces.
Particle physicists, quantum field theorists, and advanced students seeking to deepen their understanding of loop integrals and dimensional regularization techniques.
Breo
So I was asked to compute loop contributions to the Higgs and compute the integrals in spherical coordinates, I gave a look to Halzen book but did not found anything. Why, when and how to make that change?
I suspect they mean spherical coordinates in momentum space ...
"[...]Change the momentum integrals to spherical coordinates[...]"
So what is the problem? Going to spherical coordinates is a standard procedure from multivariable calculus.
d^3 p \rightarrow p^2 dp d \Omega
is quite useful ...
But why? because I solved loop integrals using dim regularization and other tricks and never used the change of variables. That is why I asked when to use the change of variables instead to keep using my previous methods (Used in many loop computations by some textboks like Peskin's)
Did you perhaps use the standard forms of the integrals that you end up with in dim-reg which you can find, eg, in the end of Peskin? How do you think these integrals are evaluated?
oh!
On the unit sphere area?
why "unit" sphere area?
I am still wondering haha
Do not know for now... tip for clairvoyance?
The entire point with dim reg is to rewrite the integral in 4-d as a limit of an integral in d "dimensions". Interpreting it as the area of a d-1-dimensional unit sphere and an integral where ##p^{d-1}\, dp## has replaced the volume ##d^dp##.
Likes mfb
Let's try it this way... How would you solve this integral:
\int \frac{d^3 p}{(2 \pi)^3} \frac{a }{|p|^2+m^2} e^{-i\vec{p} \cdot \vec{x}}
Why saying a unit sphere? This doesn't make sense, exactly because the ##d^d p## is a volume. The d^d p = |p|^{d-1} dp d\Omega_{d-1} is a volume element of an "hypersphere" between radius ##p## and ##p+dp##.
edit: I think I figured it out
Yes, exactly. I took one step extra and integrated the ##d\Omega##. This gives you the area of the d-1-dimensional unit sphere.
