Why two men can't lift a 2 ton car but can push same car
  • Thread starter Thread starter shaks
    Car Lift Push
Two men struggle to lift a 2-ton car due to the significant downward force of gravity, which they cannot overcome with their combined strength. However, they can push the car horizontally because it involves overcoming rolling resistance and static friction, which requires less force than lifting. Once the car is in motion, momentum helps maintain its movement with less energy needed to keep pushing. The discussion also touches on concepts like mechanical advantage and the role of friction in lifting versus pushing. Overall, the physics of force, friction, and momentum explain why pushing a car is feasible while lifting it is not.
shaks
Hi Guys,
I am wondering that what physics involved here.
1. Why two men can't lift 2 ton car at 1 meter height but can push same car up to even 1000 meter.
2. At start car push takes much energy but later it requires less energy to push
So weight is same but 2 men can't move car vertically but can move car horizontally up to long distance?
Also specially once moved, why its easier to keep pushing car.
What physics and equations involved here. Can anyone post here?
Shaks
1. What supports the weight of the car when lifting vs when pushing?
2. Look up "rolling resistance", and "static friction" as opposed to "kinetic friction".
... look up Newton's Laws of motion. Momentum keeps the car moving without any force at all.
Consider power vs energy.
What if the car is suspended in air by a chain, and the chain goes via a pulley so the chain is horizontal after the pulley, and some handles are attached to the end of the chain. Could the two men push the handles such that the car was lifted? What if the car rested normally on the ground and there was no pulley, just the chain?
There is a great amount of downward force exerted on the car by gravity, and 2 men by themselves are incapable of exerting a greater amount of force against gravity (upwards), so the car doesn't move when they try to lift it. In contrast, moving a car up a ramp allows you to exert a smaller amount of force over a larger distance to move the car.
See here: http://en.wikipedia.org/wiki/Inclined_plane
And here: http://en.wikipedia.org/wiki/Mechanical_advantage
Likes shaks and The Un-Observer
Go through Newton's law.
Consider free body diagram of car.
When pushing consider free body diagram of wheels. Take static and kinetic friction.
Static friction acts till you start moving the car. Although friction opposes applied force it supports rotation of wheels.
This is the easiest answer to understand for a beginner like me. :)
Thank you everybody.
Shaks
Shaks
One question. Were you asking why two men could push a car across 1,000 meters of flat ground, or why they could push a car up 1,000 meters in height even though they can't directly lift it?
This one
So the reason they need less energy to keep pushing car on ground is because of momentum.
What's equation of momentum for linear (this car example) and object moving in vertical circular path?
Shaks
shaks said:
This one
Ah, my mistake then. I thought you were asking something else. In that case, ignore the part of my answer about the ramp and pay attention to the stuff about friction that was said by others.
If the man has enough pulleys attached to the roof and to the car. The man can lift the car by himself. I know because I did this! In a sciencemuseum. (Heureka, in vantaa in finland)
But the question of friction seems good question.
Lets say you are a homemover who is carrying stuff into the client's new house.
If you have a heavy movingbox containing 20kg of stuff.
It should be way easier to push the box along the ground compared to lifting and carrying the box in your arms. Let's imagine that the floor does not suffer damage
In some african countries women often pick up drinking water from a well outside village. These women balance the water container with their hands upon their head. They suppirt the container with their hands that is.
I guess i was wondering whether that's a sensible carrying method. Of course wheelbarrow would be more effective.
