Why wasn’t gravity included in the potential energy for this problem?
The discussion revolves around the inclusion of gravitational potential energy (GPE) in the analysis of a vibration problem involving a spring and a hanging mass. Participants explore whether GPE should be considered when deriving the equation of motion for the system, examining the implications of including or omitting it in the context of simple harmonic motion (SHM).
  • One participant questions why GPE is not included in the solution manual for the vibration problem, seeking clarification on its relevance.
  • Another participant suggests adding GPE to the analysis to see what equations result, indicating that it could lead to a term that simplifies after differentiation.
  • Some participants reference the behavior of a mass oscillating vertically on a spring, noting that gravity may cancel out in the equations governing the motion.
  • Several participants provide their own calculations for potential energy, including both spring and gravitational components, leading to a derived equation of motion that incorporates GPE.
  • One participant emphasizes that while GPE can be included, it may cancel out in the final equations for SHM, suggesting that its omission might be justified in certain contexts.
  • Another participant argues that omitting GPE feels arbitrary and that it should be included, as it affects the system's equilibrium and the resulting differential equation.
  • Discussion includes the notion that including GPE makes the differential equation non-homogeneous, introducing a constant forcing term that affects the equilibrium position.
Participants express differing views on the necessity of including gravitational potential energy in the analysis. While some argue it can be omitted due to its cancellation in the equations, others contend that it should be included for clarity and completeness. The discussion remains unresolved regarding the best approach to take in such problems.
Some participants note that the equilibrium position of the system is influenced by gravity, which complicates the analysis. The discussion highlights the dependence on definitions and assumptions regarding the treatment of potential energy in oscillatory systems.
SafiBTA
Derive the equation of motion using the principle of conservation of energy
T = ½ m ẋ² + ½ J₀ θ̇²
x = 4 r θ
U_spring = ½ k (4 r θ)²
(What’s confusing me is: shouldn’t there also be a gravitational potential term U_g = m g x ?)
I’m looking at the attached vibration problem. The solution in the manual includes the spring potential energy but does NOT include the gravitational potential energy of the hanging mass.
Can someone explain why gravitational potential energy is not included when deriving the equation of motion? I tried asking ChatGPT but kept going in circles and couldn't figure out.
Thanks!
Why not add GPE to the analysis and see what equations you get?
As I understand, there will be an mgx term that will turn into mg after differentiation
Have you ever studied a mass oscillating vertically on a spring? It might be easier to look at that problem first and figure out why gravity cancels out of the equations. That is to say, the period of the SHM depends only on the spring and not on gravity. See here, for example:
https://phys.libretexts.org/Courses...anical_Phenomena/2.05:_Spring-Mass_Oscillator
The problem you have is more advanced and I suspect that the author expected you to know this already from your previous studies.
If I include the GPE, I get:
U_gravity = m g (r θ)
So the total potential energy is:
U = 8 k r² θ² + m g r θ
Now include the kinetic energy:
T = ½ (m r² + J₀) θ̇²
Now apply conservation of energy:
d/dt (T + U) = 0
Therefore the equation of motion is:
(m r² + J₀) θ̈
+ 16 k r² θ
+ m g r
= 0
d/dt (T + U) = 0
(m r² + J₀) θ̈
+ 16 k r² θ
+ m g r
= 0
This doesn't take into account that the equilibrium position depends on gravity. See the analysis I linked to.
Thanks! I read through your link on the vertical spring mass.
I understand that:
- When the mass is hanging vertically, the spring is stretched but not "fully stretched".
- Vertical spring mass system can still be assumed as horizontal spring mass system.
- The displacement variable in the potential energy term is zero at this equilibrium position.
I still don't understand why potential energy due to the gravity would not be taken into account.
I understand that:
It is taken into account. See figure 2.5.4 and the subsequent calculations. But, it cancels out of the final equation for SHM.
Once you know this, you don't necessarily have to include gravity in future problems. You can assume it's going to cancel out.
Given the method, I think you should include the potential energy due to gravity (though you should've had ##-mgx##). It feels a bit arbitrary to omit it just because you might happen to know from a different analysis it effectively won't matter. It's straightforward to see it does indeed cancel out.
As you found, including the gravitational potential energy makes the differential equation non-homogeneous with a constant forcing term. The particular solution is ##\theta_0 = \tfrac{mg}{16kr}##. Note that this is the angle through which the pulley rotates to reach the new equilibrium point. The general solution to the differential equation is ##\theta(t) = \theta_0 + \theta_h(t)## where ##\theta_h(t)## is the solution to the homogeneous differential equation. In other words, the system oscillates about ##\theta = \theta_0##.
Alternatively, you can take ##\theta=0## and ##x=0## to be around the new equilibrium point. Then the potential energy of the system should be
\begin{align*}
U &= \tfrac 12 k [4r(\theta + \theta_0)]^2 -mgx \\
&= \tfrac 12 (16kr^2)(\theta + \theta_0)^2 - mgr\theta\\
&= \tfrac 12 (16kr^2)\theta^2 + (16kr^2)\theta_0\theta + \tfrac 12(16kr^2)\theta_0^2 - mgr\theta\\
&= \tfrac 12 (16kr^2)\theta^2 + \tfrac 12(16kr^2)\theta_0^2
\end{align*} Since ##16kr^2 \theta_0 = mgr##, the linear term from the spring's potential energy cancels the gravitational potential energy term, and you'll obtain the homogeneous equation after differentiating.
  • · Replies 30 ·
  • · Replies 20 ·
