Why we use relative permeability
Relative permeability is used in electromagnetism because it simplifies the understanding of how materials respond to magnetic fields, particularly in applications like transformers. Absolute permeability includes a constant that can complicate calculations, whereas relative permeability directly relates to the material's response compared to a vacuum. The relationship between magnetic field strength (H) and magnetic flux density (B) is expressed as B = μH, where μ is the absolute permeability, but using relative permeability (μ_r) provides clearer insights into material behavior. Theoretical discussions highlight that while absolute permeability exists, relative permeability is often more practical for analyzing magnetic properties. Understanding these concepts is crucial for effectively designing and utilizing electromagnetic devices.
janu203
Why we use relative permeability if we have absolute
permeability in electromagnetism?
Because it's easier ?
Perhaps you want to show some examples where you think different ?
I am more concerned regarding the theoretical aspect. Why cannot we just take absolute permeability of any material? In fact i have started reading about transformers and there i found relative permeability.
Theoretical aspect ? Is ##\vec B = \mu \vec H## absolute enough ?
who is 'we ' ?
Who say we can not ?
I can't guess where you found this. Oherwise I could try to explain... Please tell us where.
Well, while permittivity and permeability of the vacuum, ##\epsilon_0## and ##\mu_0## are mere conversion constants from unnatural SI units to natural units, ##\epsilon_r## and ##\mu_r## are effective physical properties of the material, derivable from the microscopic structure of it in terms of linear-response theory.
Likes nasu
The relative permeability ## \mu_r ## gives the factor that the magnetic field in the core material is increased by over the applied magnetic field from the current in the conductor coils of a solenoid or transformer. The absolute permeability ## \mu=\mu_o \mu_r ## has an extra factor of ## \mu_o ## in it, (in SI units), which obscures this simple result. ## \\ ## In c.g.s. units, ## B=\mu H=\mu_r H ##, this problem is absent, because ## B=H+4 \pi M ##, without any ## \mu_o ## in front of the ## H ##.
Likes vanhees71
Thread 'What is the pressure of trapped air inside this tube?'
As you can see from the picture, i have an uneven U-shaped tube, sealed at the short end. I fill the tube with water and i seal it. So the short side is filled with water and the long side ends up containg water and trapped air. Now the tube is sealed on both sides and i turn it in such a way that the traped air moves at the short side. Are my claims about pressure in senarios A & B correct? What is the pressure for all points in senario C? (My question is basically coming from watching...
  • · Replies 21 ·
