Why Work is a Scalar Quantity: Exploring the Reason
In summary, work is defined as a dot product between force and displacement, which always results in a scalar quantity. This is because work is a difference in energies and can involve various configurations of forces and displacement. While momentum is a vector, energy is a scalar as it is determined by a physical system's positional configuration with relation to the forces at play. This can lead to potential energy being seen as a scalar and kinetic energy as a vector, depending on the observer's frame of reference.
abrowaqas
114
We know that work is the dot product between force and displacement .. so dot product always gives scalar (horizontal projection etc) hence work is a scalar quantity?
I want the reason behind it...
we always do work in specific direction..
suppose a man in appliying force at the angle of 30 in the horizontal distance to cover displacement of 3m... hence he is doing work in the direction of displacement..
clearly stated from this example that work always has direction.. then
why it is scalar quantity ? in its actual sense..
Work is a difference of energies. It might be tempting to say that kinetic energy is a vector, but it would make no sense for potential, heat and etc.
Is he doing work in the direction of the displacement or in the direction of the force? Why?
What about a pulley? Do pulleys violate the conservation of energy by changing direction? How can you avoid having a pulley change the direction of work in your proposal?
The work doesn't depend on the direction. You can always change the direction of the applied force using machines like pulleys and such. It doesn't matter which way you pull.
DaleSpam..
i got the point of your questions. but u quote examples both are related to the circular motion ...
what about the work in the rectilinear motion ?
Huh? Neither of my questions were about circular motion.
It just doesn't make sense given its definition, its a dot product which is F1x1 + F2x2, that's a scalar; its units are Joules, how can an energy have a direction? Would two energies with equal magnitude and opposite direction sum to zero in this world? Doesn't that violate conservation? How do you pick what direction work points in? Is it parallel to F or x? What if you know the work done by a system is equal to heat lost? Is heat a vector as well?
It shouldn't need explaining, it's defined that way. But the above should convince you that alternate definitions lead to big problems.
Likes Sundayemere
Thanks mLkey W.
You gave good explanation . I got it ..
Note that besides kinetic energy, we have another motion-related quantity which is a vector, namely momentum. Just as an object's kinetic energy changes because of the net work done on it, so does the object's momentum change because of the net impulse acting on it (force x time in the simplest case). And impulse is a vector, like momentum is.
Recall that work is defined as a discrete change in energy, so you're question really boils down to "why is energy a scalar quantity." The answer to that question is simple. Energy is all about a physical system's positional configuration with relation to the forces in play, like for example the location of an object in a gravitational field. A physical system can have many different configurations which all share the same energy value. To continue with the example, an object at a distance ##d## from a gravitational source has some energy value. Yet, there are lots of ways to place an object at a distance of ##d## from said source. Namely, you can place it anywhere on a sphere of radius ##d## (with the source in the center). Naturally this sort of configuration-energy will be a scalar with no direction. If that physical system converts the positional energy into motion (kinetic) energy, the the motion energy must be scalar by inheritance.
If you want to give energy a "direction", then the sum of that energy in a system is simply the "gross kinetic energy" of that system. Potential energy in that sense is simply energy not having a net direction. This can be of an unknown arbitrary amount (at least E=mc^2). Of course, whether energy has a net direction or not is relative to an observer, so what looks like potential energy in one frame looks like kinetic energy in another frame.
1. What is a scalar quantity?
A scalar quantity is a type of measurement that is described solely by its magnitude or size. This means that it does not have a direction associated with it.
2. How is work defined as a scalar quantity?
Work is defined as the product of a force applied to an object and the displacement of the object in the direction of the force. Since displacement is a vector quantity, it has both magnitude and direction. However, when calculating work, we only consider the magnitude of displacement, making work a scalar quantity.
3. Why is it important to understand why work is a scalar quantity?
Understanding why work is a scalar quantity helps us to accurately calculate and measure the amount of work being done in a given situation. It also allows us to simplify calculations and focus on the magnitude of displacement, rather than the direction.
4. Can work ever be a vector quantity?
Yes, in some cases, work can be a vector quantity. This occurs when the force and displacement are not in the same direction. In these situations, we use vector calculations to determine the work being done.
5. How does understanding scalar and vector quantities relate to real-world applications?
Understanding scalar and vector quantities is crucial in many real-world applications, such as engineering, physics, and even sports. For example, engineers use scalar and vector calculations to design structures and machines, while athletes use these concepts to improve their performance in sports.
  • Mechanics
  • Mechanics
10K
  • Mechanics
