Will a DC device work if I connect the polarity wrong?
  • Thread starter Thread starter Kurdt
    Dc Product
6 replies · 3K views
Staff Emeritus
Is a product that requires a DC power supply but doesn't have any info on the polarity able to work with both polarities?
I'd like to find out before I try it, lest I knacker my device.
Thanks :smile:
In general yes, it would have a full wave bridge rectifier at the input, to provide "polarity insensitivity".
What is the device? Can you provide a link to a datasheet or specification?
Hey berkeman. Thanks for the reply. The best I can come up with is the following but its not exactly the same.
http://catalog.belkin.com/IWCatProductPage.process?Product_Id=252506
Mine has the same basic product code but looks slightly different. I think its an older model.
What does the power input opening look like? Is it a coaxial barrel jack/plug? Those are traditionally positive tip, but not always. There should be some indication of + or - tip, maybe just hard to see if it's molded into the plastic instead of shown on a label. Does the label on the bottom of the product not indicate the polarity of the power input?
Just a power jack like these:
http://cwe.com.tw/kmportal-deluxe1/img/pictures/r/R0007_DC-POWER.png
No moulding in the plastic nothing around the power jack except "DC 12V/1.25A", and nothing on the sticker on the bottom. Unfortunately I don't have any of the documents that came with it. I normally keep all of them in a box file and I've been right through and of course the only ones I don't have are for this particular product.
Well, there's about a 95% probability that it's positive tip. You could try contacting their customer support folks to double-check. They should have a diode bridge inside (maybe open it up and check?), or at least a blocking diode to prevent knackering.
Is contacting their support or opening it up an option?
Yes I could contact them. Just thought it would be worth a go asking on here :biggrin:
Thanks berkeman.
