Will Siphons Function in a Vacuum Without Air Pressure?
  • Level: Undergrad
  • Thread starter moronthat
    Vacuum
4 replies · 3K views · last reply
moronthat
The Oxford dictionary is about to change its definition of a siphon to remove the reference to air pressure as being required. Will a siphon work in a vacuum?
No the water will boil.
Although a siphon doesn't run on air pressure, air pressure still has an effect.
The main limit on a siphon is that the head of water (the distance between the surface of the upper level and the top of the siphon hoop) can't be more than the height of a column of water supported by atmopsheric pressure (ie 9.8m)
At lower pressures the maximum height of the loop will decrease and in vacuum it reaches 0
moronthat said:
I didn't say the liquid was water.
Doesn't matter - it will still have a finite vapour pressure.
The mechanism of a siphon isn't air pressure - but you can't have a loop height more than the maximum column of the liquid that can be supported by air pressure.
