Will the trains ever be at the same distance from the origin?
  • Thread starter Thread starter GoodTimes
    Collision Train
The problem involves two trains, Train A and Train B, moving at different velocities, with Train A applying brakes while Train B continues at a constant speed. The initial distance between the two trains is given, and the question revolves around whether they will collide and, if so, where this collision will occur.
  • Participants discuss various kinematic equations to determine the distance traveled by each train and whether they will collide. There are attempts to apply different formulas, and some participants express confusion about the units and calculations involved.
Several participants have shared their calculations and reasoning, with some suggesting the use of kinematic equations to model the motion of both trains. There is an ongoing exploration of the initial conditions and how they affect the outcome, with no clear consensus on the final answer yet.
Participants are grappling with the initial conditions, particularly the initial positions of the trains and how to incorporate them into their calculations. There is also a mention of the need to consider the time of collision and the implications of negative time solutions.
GoodTimes
Train A travels with the velocity v= 30m/s, suddenly the driver sees another train ahead, Train B which travels with the velocity v=10m/s. Immediately Train A's driver starts the brakes ( a=1m/s²) while Train B still travels with its velocity. The moment A starts the brakes the distance between A's front and B's back is 200m.
Will both trains collide? If yes, where?
v1=30m/s
v2=10m/s
a=1m/s²
distance=200m
i searched the internet and found an equation:
s= v² / 2a
I was going to try it this way but ended up being confused. cause i wouldn't get metres out of it, instead seconds
unknown person's attempt
my attempt:
s= 30m/s / 2*1m/s² = 30m/s * 1 / 2m/s²
I don't know how to get a length out of this equation.
Ok I tried another equation
s=1/2 * (deltaV)² / a
s= 1/2 * (30m/s) ² / 1m/s²
s=1/2 * 900m²/s² / 1m/s²
s=1/2 * 900m/ 1
s=450m
is this correct? I would be so glad and happy if it was, usually I feel so dumb since I started university
I calculated that they do collide but i don't know how to calculate where
How do I find out where they collide?
Train A travels 30seconds 450m
during that time Train B travels 150m (+200m) it is less , so they collide.
Maybe you should start by trying to write the kinematic equations for both Train 1 and Train 2 given their velocities in terms of time. Then calculate the difference in distance as
##x_{A} - x_{B}##
The introductory physics equation you are looking for is:
##x(t) = v_{0}t + \frac{1}{2}at^{2}##
where ##x(t)## is the distance, ##t## is the time, ##v_{0}## is the initial velocity, and ##a## is the acceleration.
As an extra hint, you should have two separate equations of the form:
##x_{A}(t) = v_{0,A}t + \frac{1}{2}a_{A}t^{2}##
##x_{B}(t) = v_{0,B}t + \frac{1}{2}a_{B}t^{2}##
##x_{A} - x_{B} = v_{0,A}t + \frac{1}{2}a_{A}t^{2} - v_{0,B}t - \frac{1}{2}a_{B}t^{2}##
But several terms in these equations equal zero (which ones?). It's important to note that you do not know the time of the collision (if there is one), but you can always calculate it using the quadratic formula. The important thing is that if one or both of the two solutions for time may be negative.
##x_{A} - x_{B}##
thanks a lot for helping me
i calculated both and got x_{A} - x_{B} = 600m
is this correct and even possible? cause how are they supposed to collide after 600m if Train A stops completely after 450m?
Ahh...I apologize, I forgot to add one more term to the equations:
##x_{A}(t) = x_{0,A} + v_{0,A}t + \frac{1}{2}a_{A}t^{2}##
##x_{B}(t) = x_{0,B} + v_{0,B}t + \frac{1}{2}a_{B}t^{2}##
We need to take into account the initial displacement between the two trains.
You should get that the trains collide when ##x_{A} - x_{B} = 0## and your time should be an integer number.
I need a bit more help, i don't know what to use as xoa and xob :-(
You choose any convenient point on the railway line to be the point you'll call x = 0. Each train can then be located relative to this point.
You'll then be looking to find whether there is ever a time, t, when the trains are identical distances from that origin.
Xoa and Xob are therefore the distances from the origin of those trains at the start of observations, i.e., at t = 0.
  • · Replies 84 ·
  • · Replies 47 ·
