Will water of uniform temperature with perfect insulation stratify?
  • Context: Undergrad
  • Thread starter Thread starter Ken Fabian
    Insulation Temperature
The discussion centers on whether water of uniform temperature, when perfectly insulated, will stratify. Participants explore theoretical aspects of thermal dynamics, convection, and molecular behavior in fluids, considering various conditions and models that could influence stratification.
  • Some participants suggest that without heat exchange, the temperature of the water should remain uniform, and any heating or cooling must be below a threshold to avoid overturning circulation that disrupts homogeneity.
  • Others argue that the nature of the water and its containment conditions could significantly affect the outcome, indicating that different scenarios (like natural lakes versus contained pure water) may yield different results.
  • A participant proposes that in the presence of gravity, molecular motion could lead to a gradual migration of molecules, potentially creating a thermal gradient, despite the initial uniform temperature.
  • Another participant challenges the mixing of models, asserting that the continuum model and particle model should not be conflated, particularly regarding buoyancy and molecular behavior.
  • Some express skepticism about the likelihood of stratification occurring, considering the effects of Brownian motion and other heat transfer mechanisms that may promote temperature homogeneity.
  • A participant raises the concept of lapse rates and questions whether an insulated system could exhibit stratification without specific boundary conditions or external influences.
Participants do not reach a consensus on whether water of uniform temperature will stratify under perfect insulation. Multiple competing views and models are presented, with ongoing debate about the influence of molecular dynamics, boundary conditions, and the nature of heat transfer.
Participants note that assumptions about uniform temperature and perfect insulation may not account for all variables, such as molecular behavior and external influences that could affect thermal dynamics.
Ken Fabian
In another thread I made this comment -
Ken Fabian said:
I don't expect water of uniform temperature with perfect insulation to stratify - but am not so sure of that to claim it cannot. But I do expect (by reason) that heat conduction within still water will tend to maintain temperature homogeneity.
My own reasoning says that without any heat exchange - without any cooling or heating affecting it - the temperature will remain uniform. I also expect that any such heating or cooling will have to be below a threshold - be too weak to cause an overturning circulation that would break up any stratification - to become stratified; with an overturning circulation the contents should get well mixed and be (close to) homogeneous in temperature.
I expect the transition between slow convection that makes stratification and convection strong enough to break up stratification and get homogeneity could get complex, so will begin with looking at those two states
I am interested in whether this is true ie, am I missing something?
Science news on Phys.org
Knowing what you mean by water, containment or basin, and environmental conditions would be helpful. Natural water in a lake is certainly completely different from pure ##H_2O## in a bottle, shielded from any electromagnetic radiation.
By definition the answer is no, unless you throw in a confounding factor like a temperature distribution not contradicting your "uniform temperature" assumption.
Leaving aside your comment,
it might be better to study stratification, and easier to understand, with two separate fluids, rather than water of homogenous chemical content.
Immiscible - oil/water
Semi-immiscible - plain water/salt water
Miscible - alcohol/water
For the immiscible, you can consider that the density of the fluids is a constant, and never will the little packets of each combine, but rather appreciate the fact that that the lighter packets will always rise through the more dense packets.
For semi-immiscible, the interface between the two layers is distinct, but mixable. Consider the melting of icebergs and river flow of water into salt sea water. One fluid is solvent/solute; the other pure fluid.
Miscible - here we have a solute/ solvent.
For experiment, add a dye of different colour to each.
Note that the depth of each layer, and width, in the container, can determine the turbulence produced in each by heating the bottom fluid, preferably at a side wall, acting as a plane of symmetry, assuming a fictitious same volume on the other side of the wall.
Maybe this helps. I don't know. But these would be/are real world problems and perhaps better luck finding solutions that the limited water/water problem.
I will take a different approach.
In the presence of gravity, and given that every molecule in the water has a slightly different velocity, I would expect a gradual migration of momentarily-slower molecules, towards the bottom, while momentarily-faster molecules, migrate towards the top. That will generate a small but continuous thermal gradient.
The process is driven by the faster molecules having a greater volume, so lower density, by virtue of their velocity, and so greater pressure on their immediate neighbours.
The gradient will increase, until the temperature difference between the top and the bottom, reaches equilibrium with the thermal conductivity of water.
I think that you are mixing models here. The continuum model of fluids where the concept of buoyancy exists associates greater volume with higher temperature. The tiny particle model where particles have velocities does not associate volumes with particles based on their speed.
The continuum model does have the concept of an adiabatic lapse rate. But, for liquids, this is quite tiny.
Yes, I am mixing models, because I believe reality lies somewhere in between.
The assumption that no heating or cooling takes place, ignores the fact that the fluid has a statistical spread of parameters at the molecular level, and that energy exchange is continuous between the molecules of the fluid. I expect it will be a small effect, that can usually be ignored if there is any external heating or cooling, which in this case there is not.
I'm not reading anything that makes me think it will stratify but I hadn't considered lapse rates.
Russ, should I give you an upvote for agreeing with me? Not necessarily the best reason but I do think you are correct.
I don't think my basic understanding of convection and how temperature differentiation (ultimately stratification) arises is flawed. I made it about water and perfect insulation but any fluid with perfect insulation should do.
I did wonder something similar to Balencore's suggestion might arise - statistically unlikely hot or cold spots big enough to persist, with subsequent convection - but thinking about it I think jbriggs444 has the right of it.
I am not aware of that occurring and am inclined to think the scales at which Brownian motion are working will be extremely unlikely to cause hot or cold spots that can persist. The extent to which heat transfers by other means than Brownian motion - IR emissions and absorption inside the insulated container - seem likely to work to homogenise temperature.
Thanks, that does add a factor I hadn't considered. I wouldn't expect any convection to arise within a fluid at equilibrium in a column but if starting with homogenous temperature top to bottom it will not be at equilibrium? I'll stir that possibility in and see if it rises to the top or settles to the bottom.
My dog just looked over my shoulder. He mumbled something about Entropy in a closed system.
Faster molecules don't have a greater volume. The spacing between the molecules is larger, so the same number of molecules will occupy a larger volume.
Are you envisioning that gravity imposes a different acceleration on faster particles than on slower particles?
The atmosphere is typically temperature-stratified, so it can be said to have a lapse rate. The atmosphere's boundary conditions and the properties of "air" help determine what this lapse rate actually is at any given location and time.
Your question is whether an isothermal "ocean" that is insulated will stratify in the first place. Without any interesting boundary conditions like those of the atmosphere, what would create a stratification and hence a lapse rate?
Maybe it would be interesting to ask, what kinds of boundary conditions (or other forcing) are sufficient to cause an isothermal, but otherwise realistic, ocean to stratify?
No.
"Will it, or will it not, stratify" ?
If you look sufficiently closely, it will stratify.
If you step back, you can ignore that stratification.
  • · Replies 27 ·
  • · Replies 28 ·
  • · Replies 16 ·
  • · Replies 25 ·
