zuz
- 100
- 36
How do they measure wind chill factor?
It's even worse when in the news they seamlessly mix or jump back and forth between the real temperature and wind chill.jim hardy said:I hate that "Wind Chill" hype.
It doesn't feel like the temperature is any lower,
it feels like temperature is what temperature is and the wind is blowing..
DrClaude said:And even worse than the wind chill is the humidity factor.
I think of wind chill as how quickly heat is removed from an object, the object can be ether a person or a bowl of water.zuz said:Please correct me if I'm wrong, but I thought wind chill is a measurement of how cold it feels. A bowl of water does not feel anything
russ_watters said:It's even worse when in the news they seamlessly mix or jump back and forth between the real temperature and wind chill.
Your example was poorly selected for your point: there is no frostbite risk in an 8F windchill if it is 35F outside. Even when it is below freezing, wind chill is not well tied to frostbite risk. Worse, while for a given person the risk of both goes up with lower wind chill, for a person with more body fat the frostbite risk is increased while the hypothermia risk is lowered.DaveC426913 said:Frankly, I think y'all are missing the point.
Wind chill factor and humidex are not comfort issues; they are health and safety indexes.
If a thermometer reads 35 degrees Fahrenheit outside and the wind is blowing at 25 miles per hour (mph), the windchill factor causes it to feel like it is 8 degrees F. In other words, your 98-degree body loses heat as though it is 8 degrees outside.
The WCF tells you how to dress and how to behave so as not to suffer from hypothermia, frostbite, etc.
russ_watters said:And none of these issues of the science have anything to do with the additional issue of news hype.
DaveC426913 said:If a thermometer reads 35 degrees Fahrenheit outside and the wind is blowing at 25 miles per hour (mph), the windchill factor causes it to feel like it is 8 degrees F. In other words, your body loses heat as though it is 8 degrees outside.
I pulled those numbers from Google. Pretty sure I didn't suggest they were an example of frostbite risk in particular. I think you know that exposure and hypothermia can occur in a wide range of temps.russ_watters said:Your example was poorly selected for your point: there is no frostbite risk in an 8F windchill if it is 35F outside. Even when it is below freezing, wind chill is not well tied to frostbite risk.
It's easy to pick apart an imperfect system so long as you don't have to offer a better one.russ_watters said:Worse, while for a given person the risk of both goes up with lower wind chill, for a person with more body fat the frostbite risk is increased while the hypothermia risk is lowered.
More broadly, since windchill is calculated for exposed skin, walking into the wind, it can be defeated by ducking and is not valid for adjusting for heat loss through quality insulated clothing, for which wind is largely irrelevant.
I don't see that as the core topic, more of an add-on.russ_watters said:And none of these issues of the science have anything to do with the additional issue of news hype.
Not sure how that's relevant.zuz said:Again, correct me if I'm wrong, but I thought if you put a thermometer in front of a fan on a cold day it would read the actual temp.
DaveC426913 said:Not sure how that's relevant.
Humans aren't thermometers. Notably, we produce our own heat, and we lose heat via evaporation.
But is it true?DaveC426913 said:Not sure how that's relevant.
I don't mind knowing the windchill, butjim hardy said:I know reporting the weather is usually mundane - and what's wrong with calm ?
We need more calm-speak when a hurricane is approaching. Instead they feed hysteria
Seems a tad condescending.hmmm27 said:perhaps pandering to the ignorant keeps frostbite cases down.
DaveC426913 said:Seems a tad condescending.
free range idjits bike in winter snow and slushhmmm27 said:homegrown idjits
256bits said:free range idjit
