Windows 10 Explorer search box stops accepting input
  • Thread starter Thread starter phinds
    Search Windows
105 replies · 11K views
Klystron said:
True enough, just that I preferred DEC DCL control language to JCL and -- ugh -- DOS commands. Of course Sun Microsystems obsoleted PDP and VAX platforms in favor of Solaris and UNIX; so, moot point.
Back in the day (early '70s -- I was 12 or 13) a DEC 10 for time-sharing and an IBM OS/VS2 (later -> MVS) machine for batch was a system manager's dream -- later, the manager whom I'm thinking of went to work for Cray . . .
In the late '80s some people were running DOS/VSE (which has different JCL) under VM --
CICS (a transaction processing subsystem) still runs everywhere.
Back to MS Explorer search functions: my brother-in-law installed Mozilla Firefox browser on my laptop years ago. Functions much better than Explorer on several levels. Chrome OK if clunky.
In my opinion, Windows XP search is better than Windows 7 or 8 or 10 search.
RIGHT! If someone wants a searching program nearly as good on a modern Windows today, he must download something and install it. One possibility, SearchMyFiles.
Not sure I ever even had XP but what are the features there that are not in 7 and 10? I find that 7/10 search is excellent. What am I missing?
XP searching allowed the user to specify some details about the file to be searched. W10 allows user to just open a text field from taskbar and write some text for the file or filename user wants.
In XP search, we could easily specify content inside files, as well as wildcard file names and dates, and other 'details' (as @symbolipoint said it), and we could easily exclude results that were not what we were seeking.
@phinds , are you talking about searching for a file by name? Like, "I had a file called mycurrentproject.docx, but I'm not sure where it is saved?"
When I need to do that, I use the command prompt window and the "dir" command,
C: dir /s mycurrentproject*
or
dir /s *current*
I have never had much luck with the Windows Explorer searches, so I started doing it this way years ago.In win 10 the command prompt is hiding in PowerShell; you have to type "cmd" there.
or
dir /s *current*
The problem with that is that you can't cut/paste into and out of the command prompt, nor can you just click on the result, both of which make it a pain to use for this purpose.
Besides which, explorer is an EXCELLENT tool.
It has done this (losing the ability to search) to me once, after a Windows update. A reboot or two later and it was fine, and it hasn't happened since. If it recurs my plan is to reinstall Windows from scratch; it's about 18 months since I last did that which is about the median interval for my main PC.
In Windows 10 the command prompt is in C:\WINDOWS\system32, and PowerShell is in
C:\Windows\System32, also. . .
You can use PowerShell to run cmd, but you don't have to. . .
You can also copy and paste in either program. . . . 😏
OCR said:
In Windows 10 the command prompt is in C:\WINDOWS\system32, and PowerShell is in C:\Windows\System32, also. . .
Yeah, PowerShell is the new improved version but I've never bothered to learn it, I just use the old DOS standard when I need cmd. Nice thing about Win10 is that you can put a link to it in the window that comes up when you click on the windows icon (lower left) or hit the Windows button, just like you can with PowerShell.
As I recall, however, there are a couple of old DOS cmd's that won't work in the Windows version but PowerShell is more powerful if you care to learn it.
The DOS cmd does not quite look like the version in PowerShell, it specifically mimics the old DOS window.
I access command prompt via PowerShell only because in Windows explorer, you can shift right click and pick PowerShell off the menu (just like the way i could access cmd in previous windows versions).
Huh? I must be doing something wrong. I can't get what you are saying to work as you say. Shift right-click WHERE?
sorry. in windows explorer, click on the directory to select it, then shift-rightclick to open a menu. mine has "open"
"open in new process
etc
etc
" open PowerShell wi dow here"
click on that
edit: windows 10
etc
etc
click on that
Yes, that is exactly what I did. There is no "open in new process" option.
Maybe this. . . ?
sorry @phinds I'm just a user with very shallow understanding. I certainly can't explain why I see a different menu.
I changed the colors in mine. . . . 😉
Ah, I bet you mean this. . . ?
phinds said:
What version of windows are you running? Home? Pro? What?
phinds said:
EXACTLY what did you do to get that menu?
Hold the Shift key and RMC (right mouse click) on. . . This PC.
Thank you. That is very clear. It gives me exactly the same menu as you with the single exception that there is no "open in new process" in mine.
OCR said:
Or this. . .
Ah HA. THAT works on my system. Thanks. I see that this makes it easier to use Power Shell at the start since you can get to the desired folder via Explorer clicking rather than having to type type the whole path into Power Shell.
Very good. . . . 👍[/size] . ✔[/size]
I have Windows 10 Enterprise; this is a company laptop. When I shift-right_mouse_click with the cursor on my "Documents" folder:
But if I move up in Windows Explorer to the "This PC" folder and do the same I get a different menu:
So maybe there are settings our IT group includes when they build the laptop, the affect how this works.
