Windows that only absorb infrared light
Windows or materials that exclusively absorb infrared (IR) light do not exist due to the broad nature of the IR spectrum and electromagnetic spectrum overall. Infrared cutoff filters can be used, but they typically involve glass or thin-film techniques that still allow some IR absorption. Most materials, including glass, inherently absorb some IR light, making it challenging to find a perfect solution. Reflective materials like aluminum are recommended for minimizing IR transmission, as they can reflect most of the IR while allowing visible light to pass. Innovative designs, such as grating strips combined with secondary reflectors, may help achieve a balance between light entry and IR control, though they may distort visibility.
alevis
What are some of the windows or materials that are used to only absorb the infrared spectrum of light passing through the material?
That would be none - IR is a very broad range and the EM spectrum is also extremely broad.
To absorb all IR and none of the rest is a tall order.
Perhaps you are thinking of an infra-red cutoff filter?
An absorbtive filter would be glass, though you can also use thin-film techniques I guess.
Commercial flter manufacturers are cagey about exactly how they make their glass, however, practically everything absorbs some infra-red.
Example: http://lofi.forum.physorg.com/IR-Cutoff-filter-*_88.html of different materials.
You would really be better off to find something that reflects the IR, or most of it, like aluminum. Anything that would absorb IR, would have to do something with all that heat.
Some of the heat would no doubt be re-transmitted into the space you are trying to protect. You might be able to do some sort of clever dodge where you have grating strips on a window, and secondary reflectors positioned only in the visible portion of the spectrum enters the space. I have no idea how broad a range that would cover. Something like the above would let light in, but would distort looking out the window.(rainbow effect)
What mathematics software should engineering students use? Is it correct that much of the engineering industry relies on MATLAB, making it the tool many graduates will encounter in professional settings? How does SageMath compare? It is a free package that supports both numerical and symbolic computation and can be installed on various platforms. Could it become more widely used because it is freely available? I am an academic who has taught engineering mathematics, and taught the...
