with my question on insolation and power
  • Thread starter Thread starter shiftthatbogi
    Power
The forum discussion centers on calculating the maximum power output of a solar panel based on average insolation values. The average insolation in London in July is approximately 200 W/m². A solar panel with an area of 2 m² can produce a maximum power of 400 W, calculated using the formula P = I × A. Additionally, if the solar panels operate at 12% efficiency, the power output is 48 W, leading to an energy production of 1.152 kWh over a 24-hour period.
  • Understanding of solar insolation and its units (W/m²)
  • Familiarity with the formula for power (P = I × A)
  • Basic knowledge of efficiency calculations in solar energy
  • Ability to convert between watts and kilowatts
  • Research solar panel efficiency and its impact on energy output
  • Learn about solar insolation variations throughout the year
  • Explore energy conversion calculations, specifically from watts to kilowatt-hours
  • Investigate the effects of shading and orientation on solar panel performance
Students, solar energy enthusiasts, and professionals in renewable energy sectors looking to understand solar power calculations and efficiency metrics.
shiftthatbogi
The average insolation in London in July is approx. 200Wm-2. Calculate:
The maximum power that could be produced by a solar panel of area 2m2?
Im really confused, I don't really know how to start it, I am guessing i might need power=work done/time but I don't know how to work out those numbers.
Thanks
You need another formula for power. You can find that formula by considering the units in this problem.
HINT: insolation=intensity (It has units of intensity.)
Notice the units of insolation- W/m^2
Now, what is the unit for power?
Using this information about the units can you remember a formula for Power involving intensity?
I think power is measured in Watts so does that mean to work out the power I do:
W/m^2 x m^2 ??
which is 200 x 2^2 which is 800w?
Thats probably completely wrong cause I am so confused
Thanks for your help...
W/m^2 x m^2 ??
Your formula is right, but you shouldn't square the 2. The units of area are m^2, the area itself isn't squared in the formula:
I=\frac{P}{A}
Therefore, P=IA.
Your intensity is 200\frac{W}{m^2}, and your area is 2m^2.
Your looking for the maximum possible power a solar cell will produce. This will be equal to the total amount of power impinging on it(if only we had solar cells this good!)
So your answer should be P=IA= 400W, not 800W. Does this make sense?
so its 200x2 = 400 W?
Thank you so much for your help, I really appreciate it
Yes. Do you understand why it is 400 and not 800? Feel free to ask about anything that may be confusing you.
Yeah, before I had posted this question I had actually written 400 down as the answer but talked myself out of it because I started to confuse myself. I understand that m^2 is the measurement so i shoudlent square the number 2. Thanks again for your help :)
Anytime.:smile:
I do actually have one more question, I might be being stupid, but further down there is another question which is:
The power available if the solar panels are approx 12% efficient.
Im ok with this Q I think, I did (12/100)x400=48W
But the next part of the Question:
Calculate the number of kWh produced in one day.
I think I need to convert the watts to kilowatts by dividing by 1000. But the thing that is confusing me is whether in the original part of the question which states that the average insolation in July is 200w/m^2 I don't know whether this means the amount that is produced in July overall? Or whether that is per hour/per minute/per day?
48W is correct.
For the next part, kWh is a unit of energy, so they are asking for the energy produced for one "average" day in July. So, use the "average" insolation they give you. This make sense? (And yes, you convert the power from W to kW by dividing by 1000.)
Thanks a lot again. I am working this out as 48/1000 = 0.048
Hours in a day =24.
0.048/24 = 0.002 kWh
I think this is right but I will probably talk myself out of it again
Thank u :)
Hours in a day =24.
Thank u :)
No, but close. Notice your looking for energy, which is equal to power times time, not divided by time.
So you should multiply by 24, not divide by it.
You can also tell from the units. The units of your answer are kWh, not kW/h.
No problem.:smile:
