Word Problem with Kinematics Equation
The discussion revolves around solving a kinematics problem involving an object thrown from a cliff. The object starts with an initial velocity of 10 m/s upwards and lands with a velocity of 20 m/s downwards, with gravity acting at 9.8 m/s². The participant is unsure how to calculate the displacement, which the answer key states is -15 m. They have attempted to find the time of flight, calculating it to be approximately 3.1 seconds. Guidance is provided to use the kinematic equations without rounding the time to accurately determine the displacement.
Natko
An object thrown up from a cliff 10 m/s reaches a velocity of 20 m/s [down] as it lands. If acceleration due to gravity is 9.8 m/s2, what is the object's displacement? How long did it take for the object to land from the time it was thrown?
I'm not sure if all of the below are relevant, or perhaps some equations are missing.
Δx = v0t + 1/2at2
(displacement = initial velocity x time + 1/2 acceleration x time squared)
vf2 = v02 + 2aΔx
(final velocity squared = initial velocity squared + 2 acceleration x displacement
t1 = v/a = 1.02 s
t2 = v/a = 2.04 s
t1 + t2 = 3.1 s
Not sure how to find the displacement, but the answer key says it's -15m. How do I find it?
You can use either of your two equations to solve for the displacement. If you use the first, do not round off the time to 3.1 seconds.
Likes 1 person
  • · Replies 47 ·
  • · Replies 20 ·
  • · Replies 34 ·
