Work and Energy Theorem- change in acceleration
7 replies · 4K views · last reply
JhonnyO
A toy car of mass 555g is moving with speed 1.21m/s and strikes a spring mounted to the wall. The spring slows the toy car to rest with a acceleration that varies from 0 - 3.055m/s2.
Determine the spring constant.
W = -1/2mv2 + 1/2 kx2
I've seen equations like this but I don't understand the acceleration part. I think that because there is no friction the work is conservative so it equals zero. Then I solved the equation for x2 and substituted that back into the equation so that I could solve for k but the answer I got doesn't jive with the one my instructor gave me. What am I doing wrong?Thanks for your help.
Why is the acceleration part of the kinematic equation? And if there is a range (0-3.055) then what number should I insert?
Otherwise was the way I was going about solving it right?
Thanks
For kinetic energy you have used 1/2* m *va. It should be 1/2* m *va^2. Is it typo?
oh yea, sorry but the acceleration should be included?
No. a is not a part of the equation. I think there is some confusion in your notation, since I trust you didn't intend that a was a subscript of v.
KE = 1/2*m*v2
my question is still how does the acceleration factor into this problem? I'm trying to work the problem out and I'm not getting the question right I don't understand what I am doing wrong.
am I using the right formula?
You have 2 equations and 2 unknowns don't you?
You don't know k or x.
But they tell you that max a = 3.055 which means that
Fmax = .555*3.055
which is also
Fmax = k*x
You also know that
1/2*m*v2 = 1/2*k*x2
So Xmax = m*v2/Fmax
and k = Fmax/Xmax
