Work and Kinetic Energy Question
The discussion centers on calculating the velocity of an arrow shot from an archery bow, given that the work done to pull the bow back to full draw is 12 joules and the arrow's mass is 0.0185 kg. The correct approach involves using the work-energy principle, where the work done is equal to the change in kinetic energy. The final velocity of the arrow is determined to be 36 m/s after applying the equation W = ΔKE = 0.5mv². This solution confirms that all energy stored in the bow is converted into kinetic energy upon release.
  • Understanding of the work-energy principle
  • Familiarity with kinetic energy equations
  • Basic knowledge of physics concepts related to motion
  • Ability to manipulate algebraic equations
  • Study the work-energy theorem in detail
  • Learn about projectile motion and its equations
  • Explore conservation of momentum principles
  • Investigate the effects of angle on projectile range
Students studying physics, educators teaching mechanics, and anyone interested in understanding the principles of work and energy in motion.
MaZnFLiP
[SOLVED] Work and Kinetic Energy Question
The Problem/Question
The amount of work to pull an archery bow back to "Full Draw" is 12 joules. The arrow has a mass of 0.0185kg.
- How fast will the arrow leave the bow?
- How high will the arrow go if it's shot straight up?
- How far would it go if it was shot at a 35 degree angle above the horizon?
- If the arrow sticks into a 2.40kg box that is suspended from the ceiling with negligible friction, how fast will the box & arrow be moving just after the collision?
W = F\Deltax = \DeltaKE
\DeltaKE = KE_{}F - KE_{}I
Known Information
Work = 12 Joules
Mass = 0.0185kg
Velocity = ?
The Attempt
(12J) = KEf - KEi
KE = 0.5mv^2
0.5(0.0185kg)v^2 - 0.5(0.0185kg)v^2
(12J) = 0.5(0.0185kg)v^2 - 0.5(0.0185kg)v^2
(12J) = v^2 - v^2?
This is where I'm getting confused because if I use the equation W = F\Deltax, it doesn't give me a displacement so I can't use that. I can also try to use \DeltaKE. But that doesn't work for me either because I end up getting 12J = 0 which is not what I'm even looking for. I'm trying to find velocity but the way I've been doing it doesn't work out. Could someone please help me out on this?
well all the energy stored in the bow (12J) is converted into kinetic energy. Initially it is at rest (u=0),
\Delta E_k=\frac{1}{2}mv^2-\frac{1}{2}mu^2
Oh! I completely forgot about that. Okay so that now means that everything after the minus sign is canceled right? so that leaves us with <br /> \Delta E_k=\frac{1}{2}mv^2<br />
So: <br /> W=\Delta KE=\frac{1}{2}mv^2<br />
So that would mean that
<br /> 12J = \frac{1}{2}(0.0185kg)v^2 <br />
After Solving that I now got:
<br /> 36\frac{m}{s}^2
After looking at the answer sheet that is the right answer. Thanks so much for the help!
  • · Replies 16 ·
