Work by a Spring Force - Understanding Uinitial and Ufinal
The discussion centers on the relationship between work done by a spring and changes in potential energy, specifically articulated through the equation Wby spring = Uinitial - Ufinal. Participants confirm that the work done by the spring is equal to the negative change in potential energy, represented as W = -ΔU_r. The conservation of mechanical energy is emphasized, with the equation ΔE + ΔU_r = 0 illustrating the interplay between kinetic and potential energy. The conversation also highlights the importance of idealized conditions, such as the absence of friction, for these principles to hold true.
  • Understanding of Hooke's Law and spring mechanics
  • Basic knowledge of potential and kinetic energy concepts
  • Familiarity with the principles of mechanical energy conservation
  • Ability to interpret and manipulate equations of motion
  • Explore the implications of Hooke's Law in real-world applications
  • Learn about the mathematical derivation of work-energy principles
  • Investigate the effects of friction on energy conservation in mechanical systems
  • Study the dynamics of systems involving multiple forces and potential energies
Students of physics, mechanical engineers, and anyone interested in the principles of energy conservation and spring dynamics.
hquang001
Here it writes Wby spring= Uinitial - Ufinal. So is it equal to opposite of the change in potential energy ?
You can ask yourself, The work of the spring, on who is done? Well the increase or decrease in energy of that system depending on whether the potential of the decrease or increases, why? because when you include the spring as part of the system and you assume that the energy only transforms and does not escape from the system.
##E_f = W_r + E_i##
That is, ##\Delta E = W_r##
But the one that delivers energy from the spring does so as a function of decreasing its potential and vice versa
##W = -\Delta U_r##
Then the conservation of mechanical energy holds
##\Delta E + \Delta U_r = 0##
Think of potential energy as "money in the bank"; and, work done as money you spend.
Money spent = initial balance - final balance
You can also simply use the equation of motion,
$$m \ddot{x}=-k x=-\frac{k}{2} \frac{\mathrm{d}}{\mathrm{d} x} (x^2).$$
Now multiply this equation with ##\dot{x}## and integrate the result from ##t_1## to ##t_2##. What do you get?
Sorry but this is quite complicated for me, I've never seen this
So work done equal negative change of potential energy
and in case of kinetic energy, work done is equal to the change of kinetic energy
am i correct ?
am i correct ?
I never liked these general soundbites about work and energy. I prefer to think in terms of concrete examples:
A block sliding down a frictionless ramp; a block sliding down a ramp with friction.
I see the rules as reflecting the phenomena, not the other way round.
am i correct ?
It would only be true if there are no other possible potentials of other forces or interactions that could be altered in the system, that is why I understand that @PeroK does not like the idea of defining it that way very much and I share his concern.
So if no other potential is altered and you also maintain idealized statement conditions such as no friction, then ##\Delta K + \Delta W_r = 0##
Oh ok
Thank you
It's probably a good idea to think in terms of Energy being conserved (ignore any friction within the spring, which can change things anyway). Energy that's transferred from the extended spring (change in potential Energy) must all turn up in the device it's driving. If you do the process slowly enough (quasi-statically) then all the Energy from ('work done by ') the spring has to be 'done on' the driven device and you can ignore any Kinetic Energy.
The equations that have been written here will only apply to a simple, ideal spring (Hooke's Law) and the appropriate equations would actually be a lot more complicated, But there is no real need ( at least for starters) to understand the Maths in order to get the basic idea. People can get very bothered when Integral Signs turn up and can lose the message. Having said that, it's not possible to get much further without getting into the Maths so I am not offering you a free pass to avoid Maths for long.
  • · Replies 24 ·
  • · Replies 30 ·
