Work done by a force down a ramp
11 replies · 3K views
nav888
Calculate the average accelerating force down the ramp.
W = fx
E = mgh
The mass of the bike and person is 190kg
Calculate the average accelerating force from X to Y, if the bike has a velocity of 30 at point Y.
I am struggling with this question, I know that Fx = Work Done, but I also know that the only way to release GPE as KE is for gravity to do positive work on the object (for the object to fall), so in this case the work done by gravity is 190 x 9.8 x 25, so the change in GPE is -(190 x 9.8 x 25), and the KE is 1/2 x 190 x 900, but I am unsure how the accelerating force can cause a change in GPE, as I always thought that it was gravity that does that. Could someone help my understanding please?
on Phys.org
I think the "accelerating force" is responsible for adding the kinetic energy above what would be gained in considering just gravitational work from X to Y.
nav888 said:
... but I am unsure how the accelerating force can cause a change in GPE, as I always thought that it was gravity that does that.
What makes you think that the accelerating force changes the GPE? What you always thought is correct. Only the gravitational force changes the gravitational potential energy. The accelerating force changes the kinetic energy of the motorcycle.
What is the complete statement of the problem? Does the bike start from rest at the top of the ramp?
And can I add...
nav888 said:
...if the bike has a velocity of 30 at point Y.
'30' what units? mph? km/h? m/s? ...
Worth noting that this requires 'x' to be measured in the direction of the force.
Since the values are different, this tells us that one or more other forces (apart from gravity) is/are acting.
If we had, for example, a falling stone with no air resistance, then gravity (the only force) would be the accelerating force and the reduction in GPE would equal the gain in KE. But this is not the situation here.
If the motocyclist accelerates rapidly from X to Y the time taken is short.
If the motocyclist accelerates slowly from X to Y the time taken is long.
But the change in GPE is same in both cases.
And, as hinted at by @kuruman, are you sure the question is complete? I would have thought that we also need the time taken to get from X to Y.
Google image search finds the following:
https://www.thestudentroom.co.uk/showthread.php?t=5403130 said:
i) Calculate loss of GPE from X to Y = [elided]
ii) Calculate Kinetic energy at Y = [elided]
iii) The total distance travelled by the motorbike from X to Y along the ramp is 120 m. Calculate the average accelerating force that the motorbike engine provides along the ramp.
@haruspex -- do you want to point out that the problem setter is glossing over the difference between an average over time and an average over distance?
Reply
jbriggs444 said:
Google image search finds the following:@haruspex -- do you want to point out that the problem setter is glossing over the difference between an average over time and an average over distance?
Sometimes I wonder if the posters leave out pertinent information just to torment us.
I assumed it was the average over the distance, but it wasn’t clear how crude of an average they were intending.
Reply
kuruman said:
And an ill-defined distance at that.
Do you mean approximately a quarter of a circle with a radius of 25 meters isn’t 120 meters? 😉
I had not seen the 120 m distance when I posted #6.
On edit:
I would be more comfortable with this problem if it asked "Calculate the force that the motorbike engine provides along the ramp assuming that it is constant."
Reply
On edit:
Yeah, @jbriggs444 just found it. I was just making a joke. But I agree.
You knew that I would not resist.
The usual flaw that grabs attention
Rears its head in one dimension
The second adds a twist.
"Average force" is defined as a time average, ##\frac{\int\vec F.dt}{\int dt}##, but let's accept we are here asked for an average over distance. Since the force (static friction) is necessarily in the direction of travel, ##dW=\vec F.\vec{ds}=F.ds##. But force is a vector, so the average force (over distance) is ##\frac{\int\vec F.ds}{\int ds}##.
The force has to supply the energy gap ##E=\frac 12mv^2-mgh##. If the trajectory is straight down distance ##h## with ##F=0 ## then straight across distance ##x## with ##F=F_x## then ##E=F_xx## and the average force is ##\frac{(F_xx, 0)}{x+h}=(\frac E{s},0)##. (##s## being the total distance ##x+h##.)
At the other extreme, the force is only applied during descent. ##F=F_y##, ##E=F_yh## and the average force is ##\frac{(0, F_yh)}{x+h}=(0, \frac E{s})##.
What if we further modify the question to "magnitude of average (over distance) force"?
Exercise for the reader: prove that this is ##\frac Es## regardless of the trajectory and how the force varies over it.
But note how this differs from "average magnitude of .. etc.". Show that this does depend on such details.
Reply
