Work Done by Crane: Calculating Force & Acceleration
The discussion revolves around calculating the work done by a crane lifting a 425 kg bar to a height of 85 meters with an acceleration of 1.8 m/s². Two initial solutions were proposed, one incorrectly calculating the work done by gravity and the other focusing solely on the crane's acceleration. The correct approach involves considering both the change in gravitational potential energy and the kinetic energy due to the crane's acceleration. Ultimately, the total work done by the crane is determined to be approximately 419,050 J, which accounts for both the height lifted and the acceleration applied. The importance of using a free body diagram and the work-kinetic energy theorem for variable forces was emphasized throughout the discussion.
Le_Anthony
Had a question on a test went something like this;
A crane lifts a 425 kg bar 85m above the ground. The crane is lifting it upwards with an acceleration of 1.8 m/s^2. How much work is done by the crane?
W=Fd
Solution 1( the one i chose)
Since the crane is lifting the bar upwards with a=1.8 m/s^2, i took the total acceleration to be 9.8m/s2 - 1.8m/s2=8 m/s^2.
so 425 kg(8m/s^2)(85m)=2.9x10^5 J
(i believe this is work done by gravity...)
Solution 2 ( what i think might be the correct answer)
Work done by CRANE is (425kg)(1.8m/s^2 )(85m)=6.5x10^4 J.
Because they asked for the work done by crane so I am supposed to use 1.8m/s^2?
anyway, which solution was correct
thanks
Neither is correct.
Draw a Free Body Diagram for the mass being lifted. Identify the forces acting on it and write an expression for the net force. How are the net force and the acceleration related?
what is the logic of such equality acceleration are vectors so your 8m/s^2 is pointing down.
why not draw a free body diagram and find the force applied by crane- then calculate work
Is it 4.2x10^5 J
Le_Anthony said:
Is it 4.2x10^5 J
Show your work. We won't confirm or deny guesses.
To cancel out gravity add 9.8 to 1.8 bc it needs to move upward. 425 kg(11.6ms2)(85 m)
Okay, that is correct.
Suggestion: You could have gotten there quicker if you started by drawing an FBD and sorting out the forces first.
Likes Le_Anthony
Thanks. Kinda sad to know now haha but at least I know
Your equation (W=Fd) is right for a conservative force (constant force), however, I would think that if there is acceleration in the +y direction, then force has to change, and therefore is not constant. Therefore you have to calculate work done by a variable force.
For example. If we toss a ball straight up into the air, the moment it leaves our hand, to the moment it hits the ground, the only acceleration it experiences is the acceleration due to gravity (-9.81 m/s^2). Its velocity changes, gradually slowing down as it reaches the highest point, then speeding up before hitting the ground, but its acceleration is constant (-9.81 m/s^2). Are you sure the problem states that the crane is lifting the rod at a constant acceleration of 1.8 m/s^2 and not a constant velocity(or speed) of 1.8 m/s^2?
The following assumes what you have stated, that acceleration is 1.8 m/s^2
Here is what I would do, although I'm not sure if it is fully correct.
Use the work-kinetic energy theorem to find work done when the force is variable. (Note: this theorem also applies for a conservative force).
Work-kinetic energy theorem:
ΔK=W
K(final) - K(initial)=W; where kinetic energy, K, is defined as 1/2(m)(v^2).
1/2(m)(v^2)(final) - 1/2(m)(v^2)(initial)=W
Getting velocity from acceleration
Take the integral, with respect to y, of your acceleration, to get velocity. (recall that the first derivative of velocity is acceleration. In other words, the antiderivative (integral) of acceleration is velocity).
Therefore, in your problem, velocity, v, equals 1.8y evaluated from y2(85meters) to y1 (0meters)
Therefore the definite integral of 1.8dy, on the interval (0, 85) is:
velocity = 1.8(85) - 1.8(0)
Velocity = 153 m/s (Note: this seems extremely fast; 153 m/s equals 342 miles per hour. 85 meters is 278 feet. This means that if an object vertically accelerates constantly (starting from ground zero) at a rate of 5.9 ft/s^2 (AKA:1.8 m/s^2), then, ignoring the downward acceleration due to gravity, the object will be traveling at a velocity of 342 miles per hour at a height of 278 feet (85 meters).)
Now plug this value into the work-kinetic energy theorem to find work done by the crane.
Work done by the crane:
1/2(m)(v^2)(final at 85 meters above the ground) - 1/2(m)(v^2)(initial at 0 meters when the object is at rest)=W
1/2(425 kg)(153 m/s)^2 - 1/2(425 kg)(0 m/s)^2=W
4974412.5 Jules= W (this amount seems unreasonably high, but when you compare it to the work done by gravity--shown below--it doesn't seem too unreasonable)
Work done by the gravitational force during the object's upward motion:
W= -Fd
W= (m)(-a)(h) ; here, height, "h", is your displacement, "d". And F=ma
W= (425 kg)(-9.81 m/s^2)(85 meters)
W= -354386.26 J
Putting it all together:
The work done by the crane (4974412.5 J) plus the work done by gravity (-354386.26 J) equals the net work.
Work (net)= 4974412.5 - 354386.26
work (net)= 4620026.25 J
Work (net)= 4.6X10^6 J (rounded to two significant figures)
This is incorrect. You must integrate acceleration with respect to time in order to obtain velocity.
The velocity is easily obtained using one of the SUVAT equations involving velocity, acceleration, and distance. The value so obtained is quite a bit more reasonable.
Likes BreCheese
I made an error under the "Getting velocity from acceleration" heading.
Use this kinematical equation formula instead to get velocity: ((Vfinal)^2) -((Vinitial)^2)=2a(Δy)
((Vfinal)^2)=2(1.8 m/s^2)(85 meters)
Vfinal= 17.49 m/s
Using this equation, velocity comes out to be 17.49 m/s.
Now plug this final velocity into the work-kinetic energy theorem to find work done by the crane.
ΔKE=W
1/2(425 kg)(17.49 m/s)^2 - 1/2(425 kg)(0 m/s)^2=W
W= 65025 J
W= 6.5X10^4 J (like what you found it to be in your original post) lol.
But now I just read through yals most recent posts and you're saying the answer is 419050 J.
Admin, which is correct? What am I doing wrong? I understand that I integrated acceleration incorrectly (because I did not integrate with respect to time. oops.). But what am I doing wrong now? should I have chosen acceleration to be something besides 1.8 m/s^2 in the kinematic equation ((Vfinal)^2) -((Vinitial)^2)=2a(Δy)?
Shucks, sorry guys. I feel like I've gotten many insights from reading yals posts; hope I didn't confuse anyone with my incorrect posts ;/
Ah, I think my kinematic equation is wrong, or rather, can not be applied for motion with constant acceleration in the y-direction.
You found the change in energy due to the change in KE, but you haven't added in change due to gravitational PE.
The crane lifts the mass through 85 meters against gravity, and it also accelerates it to some final velocity. So a change in PE and a change in KE. The total work done by the crane is the sum of both. 419 kJ is correct.
