Work Done By Friction on a Piston, and Change in Enthelpy
This discussion focuses on calculating the work done by friction on a piston in a cylinder containing an ideal gas and determining the change in specific enthalpy in a steam turbine. The user presents two problems: the first involves finding the dissipative work done by friction when the volume decreases by 10% under a force of 10 N, while the second problem applies Bernoulli's equation to assess enthalpy changes in a steam turbine with varying velocities. Key concepts include the relationship between work, force, and distance, as well as the application of Bernoulli's equation in thermodynamic systems.
  • Understanding of ideal gas laws and properties
  • Familiarity with thermodynamic work calculations
  • Knowledge of Bernoulli's equation and its applications
  • Basic principles of fluid mechanics and piston-cylinder systems
  • Study the derivation and application of the work-energy principle in thermodynamic systems
  • Learn how to apply Bernoulli's equation in various fluid flow scenarios
  • Explore the concept of dissipative work and its calculation in mechanical systems
  • Investigate the relationship between pressure, volume, and temperature in ideal gases
Students in thermodynamics, mechanical engineers, and anyone involved in fluid mechanics or energy systems who seeks to understand work calculations and enthalpy changes in practical applications.
mmmboh
Hi, I have an assignment due tomorrow and have been working for hours and hours on it, and have done all of the questions pretty much, except for these 2 parts of questions, since it is due tomorrow morning if someone can help me out that would be great! Here they are:
1.Consider a system consisting of a cylinder containing 0.2 kilomoles of an ideal gas and fitted with a massless piston of area 0.5m2. The force of friction between the piston and the cylinder is 10 N. The gas is initially at a pressure of 1atm and the system is to be maintained at 300 K. The volume of the system is slowly decreases by 10 percent by an external force.
The question asks to find the configuration work done on the system, which I found, and it also asks to find the work done on the system by the external force and the dissipative work done on the system. I believe the work done on the system is the configuration work plus the dissipative work, but I can't figure out how to find the dissipative work. I know the force of friction, and I know W=FD, but we don't know the distance, but we know the new volume is 10% less, and I know the area...but this doesn't help with finding the distance since I don't know the height of the piston. Also I am not sure if I am suppose to integrate the FD, because I think the force changes with respect to the distance since as you push more more of the piston comes in contact with the cylinder...can someone please help! :)
2. A steam turbine receives a steam flow of 5000 kg/h and its power output is 500 KW. Neglect any heat loss from the turbine. Find the change in specific enthalpy of the steam flowing through the turbine if a) if the entrance and exit are at the same elevation and entry and exit velocities are negligible (I found this answer already) and b) if the entrance velocity is 60m/s and the exit velocity is 360m/s, and the inlet pipe is 3m above the exhaust.
Part b I can't figure out, I know Bernoulli's equation, but when I plug in the given velocities and heights it doesn't give me the right answer for the enthalpy. Can someone help me out please?!
Thank you so much :D
Any help please? Assignment is due tommorow :(
Anyone?
you guys are in my class, could you wear bright colors tomorrow to solve the mystery of who you are?
good luck figuring it out. We guessed that it was the change in volume divided by the area, to calculate the change in displacement.
  • · Replies 28 ·
  • · Replies 58 ·
