Work done on a conical pendulum
brotherbobby
The diagram below shows a conical pendulum of mass ##m##, length ##L## and vertical height ##h## rotating with uniform speed in a plane carving out a circle of radius ##r##. The tension in the (massless) wire is ##T##. Calculate the work done by the tension on the pendulum bob after one complete revolution.
1. Horizontal and vertical components of the tension force : ##T_V = T \cos \theta## and ##T_H = T \sin \theta##. (Please note the angle ##\theta## is the semi vertical angle - it is drawn or defined with respect the actual vector and the vertical, not the horizontal).
2. Newton's law for the acceleration of a body in an inertial frame : ##\vec a = \frac{\vec F}{m}##.
3. Centripetal force on a body moving with a speed ##\vec v## in rotational motion : ##\vec F = -\frac{mv^2}{r} \hat r##. (Please note that this value does not depend as to whether the rotational motion is uniform or non-uniform. In case of non-uniform motion, both ##\vec v## and ##\vec F## would be functions of time).
Diagram of a conical pendulum: a bob moves in a horizontal circle of radius r beneath a fixed pivot, with string length L, height h, half-angle θ, tension T along the string and weight mg acting downward.
The diagram for the problem is shown alongside. In the vertical (##\hat z##) direction we have ##T \cos \theta = mg##.
In the plane of the pendulum, if we take the pendulum bob at the left extreme end as shown in the diagram, we have ##T \sin \theta = \frac{mv^2}{r}## (the ##\hat x## axis of the pendulum is rotating along with it).
The first equation gives us the tension in the string in terms of the variables provided : ##T = mg \sec \theta = mg \frac{L}{h}##.
How to calculate the work done by the tension force ##-## this is where am stuck.
In particular, what is the angle that the tension has with the velocity ##\vec v## at a given instant? If I could find that angle, say some ##\alpha##, I can connect it to the semi-vertical angle ##\theta## as some ##\alpha (\theta)## and evaluate the work done by the tension by the line integral : ##W_T = \int_0^{2\pi} \vec T(\theta) \cdot d\vec l##, where ##d\vec l = \vec v dt## and the (uniform) speed can be connected to the tension, the radius of the pendulum and its mass from dividing the two equations above : ##v^2 = gr \tan \theta##.
##\color{blue}{Any\; help\; would\; be\; welcome}##.
brotherbobby said:
what is the angle that the tension has with the velocity →vv→\vec v at a given instant
In the picture the ##\vec T## is clearly in the plane of the paper, whereas ##\vec v## is perpendicular to it, towards the viewer !
Yes indeed, sorry I should have realized it. What you mean is that even though the tension ##T(\theta)## is not along the ##\hat z## direction, it is nonetheless perpendicular to ##\vec v## at this instant?
And since this instant is the same as the next, if we keep rotating our plane of paper so that ##T(\theta)## always lies on it, the velocity vector ##\vec v## will be always perpendicular to the tension for the whole motion?
If that is true, am I right in assuming that the work done by the tension force ##T(\theta)## is 0?
Yes. There is no motion in the direction of ##\vec T##.
