Work done to increase the charge on capacitor
The discussion centers on calculating the work done in increasing the charge on a 3 microfarad capacitor from 300 microcoulombs to 600 microcoulombs. The initial calculations were incorrect due to a misunderstanding of the relationship between charge, capacitance, and voltage. The correct formula for energy stored in a capacitor, U = (1/2)Q^2/C, was ultimately used to arrive at the correct answer of 0.045 joules for the work done.
  • Understanding of capacitor fundamentals, specifically capacitance and charge.
  • Familiarity with the formula for energy stored in a capacitor: U = (1/2)Q^2/C.
  • Knowledge of electric potential and its relationship to charge and capacitance.
  • Basic algebra skills for manipulating equations.
  • Study the derivation and applications of the energy stored in capacitors formula: U = (1/2)Q^2/C.
  • Learn about the relationship between capacitance, charge, and voltage in capacitors.
  • Explore practical applications of capacitors in electronic circuits.
  • Investigate different types of capacitors and their characteristics.
Students studying electrical engineering, physics enthusiasts, and anyone involved in electronics who needs to understand capacitor behavior and energy calculations.
scholio
how much work is done in increasing the charge on a 3 microfarad capacitor from 300 microcoulombs to 600 microcoulombs?
i am supposed to get work W = 0.045 joules
capacitance C = Q/V where Q is charge in coulombs, V is electric potential in volts
change in electric potential V = change in potential energy U/ q where q is charge
work W = change in potential energy U
first i calculated the electric potential at 300 microcoulombs using the first eq:
C = Q/V --> V = QC = (300*10^-6)(3*10^-6) = 9*10^-10 volts
then calculated the electric potential at 600 microcoulombs using same eq:
C = Q/V --> V = QC = (600*10^-6)(3*10^-6) = 1.8*10^-9 volts
since change in electric potential V = change in potential energy U/q ---> change in V = (1.8*10^-9 - 9*10^-10) = 9*10^-10 volts and since ---> change in U = change in V * q ---> i let change in V = 9*10^-10 and q = 3*10^-6 to get:
change in U = work W = (9*10^-10)(3*10^-6) = 2.7*10^-15 joules
i know i did something wrong because i am supposed to get work W = 0.045 joules
what did i do wrong?
thanks
your equations are wrong: Q = CV not V = QC. (didnt check if the answer is right though with this change)
i checked my equations again, the C = Q/V is correct, i solved for V incorrectly, originally i had V = QC, when in actuality it should be V = Q/C which changed my numbers to this:
electric potential for the Q = 3*10^-6, C = 300*10^-6, gave me V = 100 volts
electric potential for the Q = 3*10^-6, C = 600*10^-6, gave me V = 200 volts
so the change in electric potential V = 200 - 100 = 100volts, thus change in potential energy U = (change in V)q = 100(3*10^-6) = work W = 3*10^-4 joules
which is still incorrect, I'm supposed to get 0.045 joules work, what did i do wrong now?
thanks
The energy stored in a capacitor is (1/2)Q^2/C. Why don't you just use that?
you were correct dick, i didn't even think of using that formula you gave me, i must've forgotten about it. anyways, when i used it, i got the answer i was looking for, work W = 0.045 joules
thanks again
  • · Replies 23 ·
  • · Replies 22 ·
  • · Replies 16 ·
