Work done to move spring displacement
To calculate the work done in changing the length of a spring from 2 cm to 10 cm, the spring's stiffness (95 N/m) and relaxed length (5 cm) are essential. The force exerted by the spring is not constant, requiring integration to accurately determine work done. The correct approach involves using the equation W = ∫ F(x) dx, where F(x) is the spring force as a function of displacement. A misunderstanding of the force's constancy led to initial errors in calculations. The discussion highlights the importance of recognizing variable forces in work calculations.
gunster
A spring has a relaxed length of 5 cm and a
stiffness of 95 N/m. How much work must you
do to change its length from 2 cm to 10 cm?
k=95
Lnull=0.05
delta x = .1-.02 = 0.08
F=-kx
W=Fdcostheta
I honestly have tried everything and am beginning to think I am way off the mark and missed something. But what i tried was
W = Fdcostheta where F = -kx
Therefore, since force changes direction after the displacement is past the relaxed spring length, i used:
W = -95 * (0.05-0.02) * (0.05-0.02) cos 0 + -95 * (0.1-0.5) * (0.1-0.5) cos 180
But that was apparently completely wrong. any help please?
F = F d \cos \theta is only valid if the force is constant over the distance (not a function of x in this case). Your force is a function of x, so you will have to integrate to get the work. It's possible you can solve the problem with a energy approach if integrals are beyond your course material.
W = \int F(x) dx
EDIT: nvm realized my mistake was suppose to subtract
Thanks a lot for reminding me force is not constant XD
