Work-Energy problem involving pulley
  • Thread starter Thread starter thepatient
    Pulley Work-energy
12 replies · 9K views
thepatient
The system shown is at rest when a constant 250N force is applied to block A. Neglecting masses of pulleys and friction, determine:
a) Velocity of block B after block A moved 2 m.
b) The tension in the cable
http://imageshack.us/photo/my-images/259/photoivl.jpg/
Fnet = ma.
U = mgh
KE = 1/2 mv^2
Ui + KEi + W = Uf + KEf, where subindex i and f mean initial and final states.
I have completed this problem, but I'm not sure if this is correct. The professor said this particular problem can be done by taking both masses and the ropes as a single system and also by taking each mass as its own, separate system. I did took each as a separate system.
First, I drew a free body diagram for block A. The net force in the x direction, assuming left is negative gives me:
F - T = ma_A
1------------------250N - T = ma_A
The relationship between the position of block A and block B was obtained and determined to be:
X_A + 3X_B = constant. Taking first time derivative:
V_A + 3V_B = 0
V_A = - 3V_B. Second time derivative:
2--------------a_A = -3a_B
Using Newton's law for the y direction on block B:
up positive: 3T - W = m*a_B
3-----------3T - mg = m*a_B
Solving 1 for acceleration a_A, then using equation 2 to leave as a_B = form:
250-T/m_a = -3a_B
4----- -250+T/(3m_a) = a_B
Using 4 to solve for tension in 3:
3T - m_b*g = -m_b*250/(3*m_a) + m_b * T/(3m_a)
Subsituting for values of mass of b, g, mass of a and solving for T:
T(3-25/90) = 25*9.81 - 25*250/(3*30)
T = 64.6N
Then, with that tension, using the work energy theorem on block A:
Wtension + Wconst force = 1/2 m_a V_a^2
250*2 - 129.2 = 1/2 *30va^2
V_a = 4.97 m /s <------ left.
Using relationship:
V_a = -3Vb
V_b = 1.66 m / s Upwards.
Does that seem right...? Thanks a ton. :]
Both bodies move along the rope, there is no reason to distinguish between x and y components of velocity. When A moves to the left, B will move vertically upward. Taking "to the left" as positive direction for A, "up" is positive for B. You correctly figured out that the acceleration of A is three times the acceleration of B. So aA=3aB.
The equations for the accelerations and forces you wrote are correct with this choice of the direction of accelerations:
25-T=mAaA
and
3T-mBg=mBaB
Proceed from here, but do not forget the parentheses. You had at least one error by ignoring them.
ehild
I tried it again and more carefully this time, but used only the magnitudes of acceleration in F =ma equations. I ended up getting a tension of about 96N I think. I can try the calculation here on my phone. XD
250-T = 25a_a
3T - 30g = 30 a_b
a_A = 3a_B
Plugging 3a_B in first equation:
250 - T = 75a_B
1/75 (250 - T) = a_B =1/30(3T - 30g)
250/75 -T/75 = T/10 - g
T/75 + T/10 = 250/75 + g
T + 7.5T = 250 + 75g
Oh great now I get T = 116N :/
No wait I think that's what I got for my original calculation actually. And velocity of block A comes out to be 4.63 m/s to the left using the W-E theorem and the speed of block B a third of that value.
250-T = 25a_a
3T - 30g = 30 a_b
The masses are interchanged in the equations above: ma = 30 kg and mb=25 kg. Your first calculation was correct, T=95.9 N.
I got va=4.63 m/s, vb=1.51 m/s, but it seems all right otherwise.
ehild
You are welcome. It was a nice solution of a nice problem:smile:
ehild
thepatient can you explain how you arrived at 3T-W=mbab ?
It is the weight downwards and three times the tension in the string upwards, as the block is held by three threads of the string.
What do you mean on "the normal of its weight"?
ehild
Uh sorry my bad, I was referring to the normal reaction on an object kept on a table lol xD here it doesn't apply sorry
