- 15,536
- 1,917
CAF123 said:Mathematically, we have the first law as follows: $$\Delta U + \text{bulk}(KE + PE) = Q + W$$ The right hand side is zero, so this gives ##\Delta U = - \text{bulk}(KE + PE)## i.e the rotational kinetic energy of the water is converted to the internal energy of the water.
Your formula misses Δ-s. $$\Delta U + \text{bulk}(ΔKE + ΔPE) = Q + W$$. The work W done on the system by external forces + the heat Q transferred to the system changes its total energy , mechanical +internal. That is conservation of energy.
If a system is not in equilibrium, like the whirling water in the tank, it can do internal work, that is, its parts do work on other parts. But internal work is not subject of Thermodynamics. It investigates equilibrium states, not the process of transfer from one equilibrium state to the other one.
If the system is isolated, no work is done and no heat is added. Then $$\Delta U + \text{bulk}(ΔKE + ΔPE) =0$$. With PE also zero, $$\Delta U = -\text{bulk}(ΔKE) $$.
When the rotation stopped, ΔKE<0 and the system got into thermal equilibrium, its internal energy being greater than it was before by the original kinetic energy. But that does not mean work on or by the environment.
CAF123 said:I think I can say since the only two things that can cause the internal energy to increase are work on system and heat transfer to system, then in the eqn ΔU=−bulk(KE)+W, the first term on the right should be regarded as work. (it is not heat). Can you or someone else tell me if this is a correct interpretation?
Your problem is that you use two different equations for the same thing. One is conservation of energy:
$$\Delta U + \text{bulk}(ΔKE +Δ PE) = Q + W$$,
the other is the First Law of Thermodynamics, stating that the change of the internal energy between two equilibrium states of a system is $$\Delta U = Q + W$$.
The stirring put the system into a non-equilibrium state, and the work done changed the total energy, mechanical and internal. The following irreversible process led the system to an other equilibrium state. Such process can be treated by the methods of Non-Equilibrium Thermodynamics. http://en.wikipedia.org/wiki/Non-equilibrium_thermodynamics. Question b) refers to this process, asking the work done by an isolated system on the environment. Isolated means no interaction between the system and its surroundings - no work done by the system or on the system.
ehild
