Work required to pump - Very tricky
  • Thread starter Thread starter IntegrateMe
    Pump Work
To calculate the work required to pump seawater from a cylindrical tank, one must consider the varying heights each segment of water needs to be lifted. The tank, with a radius of 2 feet and a height of 8 feet, contains water up to 6 feet, meaning the top water must be raised 2 feet while the bottom water must be raised 8 feet. The work done is determined by integrating the force required to lift each cylindrical piece of water, leading to the formula 256π∫(8-x)dx from 0 to 6. An alternative approach involves calculating the average height the water must be lifted, which simplifies the process to finding the total weight of the water and multiplying it by the average lift distance. Ultimately, the total work required is 24,127 ft-lbs.
IntegrateMe
A right cylindrical tank is filled with sea water. The tank has a radius of 2 feet and a height of 8 feet. If the water level is now 2 feet below the top of the tank, how much work will be required to pump the sea water to the top of the tank? (The weight-density of seawater is 64 Ib/ft3.)
The answer is 24,127 ft-Ibs, can anyone figure out why?
How do you think you need to approach the problem?
deltaV = pi(r)^2(thickness) --this is of the cylindrical pieces you cut out of the whole
so r = 2
deltaV = 4pi(deltaY)
F(y) = weight = 64 Ib/ft3 (4pi(deltaY))
..and that's pretty much all i can think of?
It's very confusing, I'm sorry.
The water fills the tank to 6ft. You can find the volume of water using the volume of a cylinder V=\pi r^2 h. Give volume and density you can get the mass of water. You just need to get the energy needed to raise the water a height of 2 ft.
so using the volume equation i get V = 4pi(6) = 24pi
Then to get the force i use the work equation?
so,
W = fnint ((64 Ib/ft3)(24pi),x,0,2)
Is that it?
No, that's wrong. The water at the top of the tank only has to be raised 2 feet but the water at the bottom of the tank has to be raised 8 feet. That's why IntegrateMe is talking about "cylindrical pieces". Each "piece" has area [/itex]4\pi[/itex] square feet and, if we take the "thickness" of each "piece" to be dx, volume 4\pi dx cubic feet and so mass (64)(4\pi dx)= 256\pi dx pounds. If that pieces is at height "x", it has to be raised 8- x feet. The work done in raising that piece is 256\pi (8- x)dx and so the total work done is
256\pi\int_0^6 (8- x)dx[/itex] &quot;foot-pounds&quot;.<br /> <br /> Because the density is constant, you <b>could</b> look at the <b>average</b> distance the water must be lifted. The cylinder also has constant cross section so the &quot;average&quot; height of the water is 1/2 way up, at (0+ 6)/2= 3 feet. The water has to be lifted and &quot;average&quot; distance of 8- 3= 5 feet. Find the weight of the entire cylinder of water and multiply by 5 feet, not 2. That will give the same answer as the integral.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
