Working Examples RLC Circuit with 5V Ramp Voltage Laplace Transforms
The discussion focuses on solving current expressions for a series RLC circuit with a 5V ramp voltage using Laplace transforms. The circuit parameters are R=15Ω, L=0.4H, and C=12μF. The Laplace transform equation derived is I(s) = V(s) / (R + Ls + 1/(Cs)), which simplifies to I(s) = 1/(s(Ls^2 + Rs + 1/C)). Participants discussed the necessity of multiplying terms by s² for proper fraction decomposition, leading to the final current expression of 7.5x10^-4[1 - e^-18.75t(cos 456.05t + 41.11x10^-3 sin 456.05t)].
  • Understanding of RLC circuit theory
  • Proficiency in Laplace transforms
  • Knowledge of fraction decomposition techniques
  • Familiarity with circuit analysis and differential equations
  • Study "Laplace Transform Applications in Circuit Analysis"
  • Learn "Partial Fraction Decomposition Techniques"
  • Explore "RLC Circuit Response to Non-Constant Inputs"
  • Review "Transient Analysis of RLC Circuits"
Electrical engineers, students studying circuit theory, and professionals working with control systems will benefit from this discussion on RLC circuits and Laplace transforms.
Cooler
can anyone give me the working examples of current expressions of series RLC circuit using ramp voltage by Laplace transforms. thanks
R=15, L= 0.4H, C=12uF ...voltage 5v
You write a conservation of voltage around the loop:
-v(t) + Ri(t) + L\frac{di}{dt} + \frac{1}{c} \int i(t) \, dt=0
Take the Laplace of both sides:
-V(s) + R I(s) + LsI(s) + \frac{1}{cs}I(s)= 0
Solve for your sought after function of current:
I(s) = \frac{V(s)}{R + Ls + \frac{1}{cs}}
Remember, this solution assumes initial conditions equal to zero.
i stuck on the 1/s^2 [r + sL + 1/sC] ...do we need multiply all inside the bracket by s^2?
Yes. Then you will most likely need to do fraction decomposition. The trick will be putting the answer in a form present in your Laplace tables.
i don't get the fraction decomposition...
when i multiplied inside the bracket it gives me...(15s^2 + 0.4s^3 + 83.333x10^3 s) is this correct and what to do next?
I(s) = \frac{1}{s(Ls^2 + Rs + \frac{1}{c})}=-\frac{c^2(R+sL)}{cLs^2+cRs+1}+\frac{c}{s}
sorry i don't get the idea of how it end up that way...mind to explain? thnks
Have you googled for tutorials yet? Google "fraction decomposition" or "partial fraction decomposition"
http://www.purplemath.com/modules/partfrac.htm
Essentially, it is a procedure for reversing the addition of two fractions.
so you can say a/b + c/d = (ad + bc)/(bd)
but in partial, you start with the right hand side and find the left hand side.Effectively (though it's not the complete picture), b = s and d = (ls^2 + rs + 1/c). And the reason I chose to only distribute 1 of the s in s^2 is that 1/s and 1/(as^2+bs+c) are usually in Laplace tables.
What answer did you get?
my answer is 7.5x10^-4[ 1 - e^-18.75t(cos 456.05t + 41.11x10^-3 sin 456.05t)
  • · Replies 22 ·
  • · Replies 17 ·
