Would a 4'x8'x1' piece of glass be able to contain 60psi?
  • Thread starter Thread starter Physt
    Glass
The discussion centers on the feasibility of using a 4'x8'x1' piece of glass to contain 60 psi of pressure, with considerations for design parameters and material thickness. The user references the maximum pressure calculations for flat glass panels, noting that a 1" thick tempered glass panel can withstand approximately 2.25 psi, while a thickness of 12" could potentially handle 27 psi. The user seeks equations for calculating maximum allowable pressure for flat panels and emphasizes that pressure resistance does not scale linearly with thickness, suggesting a square relationship instead.
  • Understanding of pressure vessel design principles
  • Familiarity with material properties of glass
  • Knowledge of structural engineering calculations
  • Experience with online calculators for material load-bearing capacity
  • Research equations for calculating maximum pressure for flat glass panels
  • Explore the properties and applications of tempered glass in pressure vessels
  • Investigate safety factors in pressure vessel design
  • Learn about alternative materials for high-pressure applications, such as polycarbonate
Engineers, designers, and hobbyists involved in pressure vessel design, 3D modeling, or materials science, particularly those interested in the structural integrity of glass under pressure.
Physt
Preface: This isn't an actual project, just trying to get the design to be realistic for a 3D model in a video game.
I know most pressure vessels are round and the overall shape of this one would be round, but it's very large (about half a football field large) so it would be composed of a bunch of panels. The 4'x8'x1' piece of glass would be supported evenly on all four 1'-wide sides by being clamped into a support 1.5 inches deep (so the actual surface area would be 45"x93").
Would this be good enough to hold 60psi (actually 1atm, but from what I've read about double the pressure is a good design parameter to go by)?
What would be the maximum pressure of this design?
Does anyone happen to have the equations for a calculating the maximum pressure allowable for flat panels like this so I might plug different materials into the equations?
~30cm thick? That is a massive block of glass. The biggest window at the ISS has a diameter of 80cm and is just 2.5 cm thick (there are two glass panes behind each other so one serves as backup) - and I'm sure they have a huge safety margin built in.
From all I've fathered thus far the thickness of the glass grows quite a bit relative to the length of the shortest dimension. ~30cm is my best guess thus far based on the calculators available online for curved surfaces at approximately 122cm across with a little more for the sake of it being a flat surface.
The best calculator I've found online thus far for glass panels is http://www.dullesglassandmirror.com/glass-shelf-weight-load-calculator.aspx and a 45"x93" piece of tempered glass with a thickness of 1" and supports at 48" (closest I could get to supported along all four edges with that calculator) it comes in at 9416.25 lbs max, so divided by (45*93) yeilds 2.25psi, 27psi for 12" of thickness. So if that estimate is close it wouldn't quite be thick enough (without even doubling the psi for the sake of safety).
Guessing (hoping) that's not an entirely accurate estimate though.
The allowed pressure does not scale linearly with thickness. The square is a better estimate, so 12 times the thickness gives 144 times the pressure - a good safety factor with your values.
I really don't like weird and exotic unit systems.[/size]
Thanks, I too dislike the English system, but if one were to buy a large sheet of glass in the US it would likely be a 4'x8' pane - same goes for layered glass/polycarbonate stacks - so figured I'd try to work around that.
  • · Replies 52 ·
  • · Replies 21 ·
  • · Replies 42 ·
  • · Replies 19 ·
12K
  • · Replies 16 ·
10K
