Would rubbing alcohol and vinegar neutralize each other?
The discussion centers on the interaction between rubbing alcohol (70% ethanol) and supermarket white vinegar (8% acetic acid) when mixed for use in a windshield washer fluid tank. It is established that this mixture does not result in a typical acid-base neutralization reaction, as alcohol is classified as a very weak base. The reaction produces ethyl acetate, but requires an additional acid catalyst for esterification to occur. Concerns about potential corrosion of tubing from this mixture are addressed, with a consensus that typical windshield fluid materials are designed to withstand aggressive substances.
  • Understanding of Bronsted-Lowry acid-base theory
  • Knowledge of basic organic chemistry reactions
  • Familiarity with the properties of ethanol and acetic acid
  • Awareness of common automotive fluids and their chemical interactions
  • Research the properties and reactions of ethyl acetate
  • Learn about Bronsted-Lowry acid-base theory in detail
  • Investigate the chemical composition of commercial windshield cleaners
  • Study the effects of various solvents on automotive tubing materials
This discussion is beneficial for chemistry students, automotive enthusiasts, and anyone interested in the chemical interactions of household cleaning agents and their applications in vehicle maintenance.
alr1014
I was reading a post on Facebook about cleaning and it said to mix rubbing alcohol and vinegar and put it in your windown washer fluid tank. Someone commented that it would corrode or eat away at the tubing. I keep thinking the mixture would be an acid /base mixture and would neutralize. I was trying to tag up on it but the most I found was that it was not a typical acid base solution but another type that transfers protons to one another? Only in Gen Chem 2 so have not come across proton sharing... anyways, now I am thoroughly entrigued by the entire thing and would like to know the outcome of this mixture as a washing fluid for your car and if it is a neutralization reaction or what. Thanks for any assistance on this inconsequential matter.
Chemistry news on Phys.org
Welcome to PF;
Is alcohol a base?
Supermarket white vinegar is about 8% acetic acid
Rubbing alchohol is about 70% ethanol
The reaction produces ethyl acetate.
https://en.wikipedia.org/wiki/Ethyl_acetate
The mixture is not as effective as commercial cleaners - though it is a lot cheaper and most commercial cleaners are overkill.
Alcohol is not a base. Or, more precisely - it is a very weak base. Way to weak for a normal neutralization reaction to take place.
Protons transfer IS an acid/base reaction. I guess you think in terms of the Arrhenius acids and bases, and to classify proton transfer as an acid/base reaction you need to think in terms of Bronsted-Lowry acids and bases. Note that this is the same theory that is required to explain reactions of ammonia, so not something esoteric and rarely used.
Unless it is an isopropyl alcohol.
It won't happen just because you mix these two. Esterification requires an additional acid catalyst, preferably a strong, dessicating acid like sulphuric.
Thank yall so much for replying! But just to clarify, the solution would not corrode or otherwise eat away at the tubing? I wouldn't think that it would, but just wanting to be sure. And the Arrhenius theory sounds familiar, the other not so much. We have not talked about proton sharing, just election sharing. Is that something we will go over in organic?
Bronsted-Lowry theory is typically taught as a part of the GenChem course. Without it you won't be able to explain why ammonia solutions are basic nor why the Fe3+ solutions are acidic.
Whether the tubing will corrode - no idea. I doubt, as the typical windshield fluids can be quite aggressive, and the tubing is made to hold in their presence. But that's just a guess, which doesn't have to be correct.
You know what is hilarious? We will be going over those type of acids and bases Wednesday (decided to go look in my chem book to see if I glossed over it somehow and low and behold! ) (: if this conversation had happened then, I wouldn't feel so out of the loop lol. Thanks for all the help though!
Simon Bridge said:
Welcome to PF;
Is alcohol a base?
You must get your "rubbing" alcohol from a different store than I do. :wink:
9K
