Would the charges in each capacitors be the same ?
  • Thread starter Thread starter thereddevils
    Capacitors Charges
In a series circuit with two capacitors of different capacitance connected to a 3V supply, the charges on each capacitor are equal due to the principle of conservation of charge. The battery does not supply new charges; instead, it pumps existing charges through the circuit. When capacitors are connected in parallel, the total charge is the sum of the charges on each capacitor, while the voltage across each remains the same.
  • Understanding of basic electrical concepts, including voltage and charge.
  • Familiarity with capacitor behavior in series and parallel configurations.
  • Knowledge of the principle of conservation of charge.
  • Basic understanding of how batteries function in a circuit.
  • Study the behavior of capacitors in parallel circuits and their charge distribution.
  • Learn about the mathematical relationships governing capacitors, including capacitance formulas.
  • Explore the concept of electric current and its relationship to charge flow in circuits.
  • Investigate the role of batteries in circuits, focusing on how they influence charge movement.
Electronics students, electrical engineers, and anyone interested in understanding capacitor behavior in circuits.
thereddevils
Say there are 2 capacitors of different capacitance connected in series to a supply of 3 V . Would the charges in each capacitors be the same ?
Can i say that charges are analogous current ? If so , since current is the same throughout the circuit , hence the charges in each capacitor is the same ?
Hi thereddevils! :smile:
Not really.
Use conservation of charge …
if the charges were different, where would the extra charge have come from? :wink:
Not really.
thanks , i just read bout it a little in wikipedia and it says the principle states that charges can neither be created or destroyed . So say in a circuit , there are 5C of charges so forever there will be 5 C of charges ? Where did this 5 C of charges come in the first place , is it from the battery ? And also each capacitor will store 5 C of charges following that principle ?
Hi thereddevils! smile:
(just got up :zzz: …)
The charge goes from one plate to another … the battery pumps charge all the way from the left-hand plate of the left-hand capacitor to the right-hand plate of the right-hand capacitor.
The charge missing from one plate obviously equals the charge gained by the other plate.
For the two "inside" plates, it's the same … the charge lost by one must equal the charge gained by the other.
thanks tim and good morning , its 5pm here in Malaysia .
i kinda get the picture now so the function of the battery is to pump the charge , does it supply the charges ? Or the charges are already there in the circuit and the battery just pumps them around ?
Ok i see , so when the capacitors are connected in series , the charges are equal in each capacitors , what if the capacitors are connected in parallel ? i think it will not be the same but rather the sum would give the overall charge of the circuit .
The latter … the electrons are already in the circuit, and all the battery does is pump them round.
Yes, in parallel, the sum of the charges on the two left-hand plates (connected to one side of the battery) is equal and opposite to the sum of the charges on the two right-hand plates (and, of course, the voltage difference across each capacitor is the same).
Have a good evening! :smile:
  • · Replies 18 ·
